Author: Subject: BUILD SHED LIGHTING
matt.c
posted on 21/5/07 at 05:49 PM Reply With Quote
BUILD SHED LIGHTING
Which is the best location for my 4 strip lights?
1. On the roof, but tilted sideways for head room?
2. At the top of each shed side?
Just trying to find the best lighting angle for the lights to get the max light out of them and best for kit building ie low down.
[img][/img]
flak monkey
posted on 21/5/07 at 05:52 PM Reply With Quote
You need to diffuse the light as much as possible otherwise you get loads of shadows. Thankfully tubes are quite good at this anyway.
How about duct taping them up to try? In different places
I would guess that up on the roof is the best place, like in your first pic.
Ordered that kit yet?
Sera
http://www.motosera.com
matt.c
posted on 21/5/07 at 06:02 PM Reply With Quote
give me a chance! Only just got my shed!
DIY Si
posted on 21/5/07 at 06:10 PM Reply With Quote
I'd go for the joint between the roof and the walls, with the box screwed to the wall. Also maybe one in the point of the roof if poss.
Sun Tzu, The Art of War
posted on 21/5/07 at 06:52 PM Reply With Quote
Go for the beam moutned ones- they'll help when you're bending over trying to look into the inside of the engine bay etc.... The wall/ceiling mounted ones will illuminate the outside of the car well (but that will happen fairly well due to reflected light) but if you bend over the look "into" the car you'll cast a shadow which (unless your ceiling is very high) the opposite and end lights will not be able to illuminate...
SixedUp
posted on 21/5/07 at 06:56 PM Reply With Quote
Both. You can't have enough lighting
Richard
wicket
posted on 21/5/07 at 07:01 PM Reply With Quote
Paint the walls and roof white as well, makes a huge difference
posted on 21/5/07 at 07:23 PM Reply With Quote
and when using tools be aware of the effects of fluorescent lights! maybe add a single incandescent bulb somewhere, then you get a bit of heat too!
nitram38
posted on 21/5/07 at 08:15 PM Reply With Quote
As an electrician, I would advise the walls for your situation.
Having 4 lights will help eliminate shadows, but the main benefit is not smashing the lamp or diffuser (if you are using one).
On the subject of diffusers, you can buy "half" reflectors that you can mount on the edge closest the cieling, that will divert the light downwards.
[Edited on 21/5/2007 by nitram38]
matt.c
posted on 21/5/07 at 09:23 PM Reply With Quote
cheers all.
Have been messing around with a small light and found that having it wall mounted makes the most light. When they are in the roof most of the light hits the next beam and thats about it! So i think i will mount them on the walls
And also been all night painting the inside gloss white, so should be good.
Thanks again locosters
wilkingj
posted on 21/5/07 at 10:05 PM Reply With Quote
Dead Right, cheapo emulsion is good enough, but makes a hell of a difference.
Best Regards
Geoff
http://www.v8viento.co.uk
