nitram38
| posted on 26/5/07 at 10:48 AM |
I need a hand!!!
Pretty please!!!!!
Anyone in Mitcham/Croydon?
Everyone I know has gone away for the weekend including neighbours.
All I need is a 30 second lift with my R1 engine from it's delivery box and straight onto a workmate. (workmate bench that is )
A cup of tea and a sandwich in exchange ! (plus a sneak preview of Project X)
Cheers Martin
[Edited on 26/5/2007 by nitram38]
novacaine
| posted on 26/5/07 at 02:01 PM |
an there was me thinking this was a post on prosthetic limbs....
sorry for the useless post
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
graememk
| posted on 26/5/07 at 02:35 PM |
nitram38
| posted on 26/5/07 at 02:36 PM |
I said a hand not a couple of a*seholes!
You're not helping much!
I have spare time and I can't do a thing!
On the engine I need to fit the sump baffle, a barnett clutch, an electric reverse kit and fit a new 4-1 manifold.
DIY Si
| posted on 26/5/07 at 02:43 PM |
How heavy is it? I can lift my blackbird around onmy own, and that must be a good bit heavier than an R1. I say this having no idea how big/strong you
are though!
Sun Tzu, The Art of War
nitram38
| posted on 26/5/07 at 02:47 PM |
are though!
It is 63kgs
I can lift it if I want to put my back out or risk dropping it. At £1800 I can't afford a problem!
It needs to go from the floor, from it's plastic delivery crate and onto a workmate bench.
Two people it will be easy. One will be a struggle.
DIY Si
| posted on 26/5/07 at 02:51 PM |
Fair enough then. I normally just have to struggle, as my mates work stupid shift patterns! Oh, and my engine only cost £400.
Ivan
| posted on 26/5/07 at 02:58 PM |
That's normally what your wife is for
And/or any kids older than 6.
nitram38
| posted on 26/5/07 at 03:42 PM |
I don't think that they can handle the bad language !
Also, experience has told me that they normally get half way and give up, leaving me struggling!
DIY Si
| posted on 26/5/07 at 03:45 PM |
Have you got anything yo can make a tower or two from? Ie lift a bit onto a little tower/table/whatever, then a bit more to a slightly higher tower,
repeat until at workmate.
flak monkey
| posted on 26/5/07 at 04:27 PM |
I lump our tt600 engine around on my own. Probably shouldnt, and suprised a couple of people by lifting it up onto our welding bench the other week
because it was in the way. Then I thought it wasn't all that heavy, weighs in at about 70kg with all the bits attached. Most people weigh more
than that.
If you can get a good grip on it thats the main thing, some rubbery gloves are good. Bend your knees not your back, and you'll be fine. Try to
lean the cylinders against your chest so its not trying to topple forward/away from you.
Take your time, plan your lift and try it. If you really dont think you can then you'll just have to wait
Sera
http://www.motosera.com
oadamo
| posted on 26/5/07 at 04:49 PM |
engine crane
| posted on 26/5/07 at 05:42 PM |
nitram38
| posted on 26/5/07 at 06:10 PM |
Don't Worry, Desyboy is on his way over.
locogeoff
| posted on 26/5/07 at 10:34 PM |
I wouldn't recomend lifting things on your own, I fitted a belfast sink in my kitchen, it said on the box "Two man lift" I'd
been lifting it on and off the base a couple of times to get everythong lined up properly when I was lifting it for the last time when my back gave
way, so there I was trying not to drop a ceramic sink with spasming muscles in my back, I folded underneath the sink and ended up having to get Dot to
lift the sink off me, ended up having a week off work but the pain was unbearable
But I'm daft I've been having back problems since I was a kid, but I just don't learn!
[Edited on 26/5/07 by locogeoff]
nitram38
| posted on 26/5/07 at 10:49 PM |
The engine is now safely sitting on the workmate, ready for tomorrows onslaught!
