Author: Subject: P2P and Torrent Help
speedyxjs
posted on 28/5/07 at 04:32 PM Reply With Quote
I cant get BitTorrent or Limewire to connect
My connection is great and i can surf fine and download other file at high speed.
Any ideas as to what the problem could be?
Catpuss
posted on 28/5/07 at 04:56 PM Reply With Quote
Possibly a firewall you are running. Possibly you are using a router with NAT enabled and havn't set it up to forward the particular port without network address translation.
posted on 28/5/07 at 07:38 PM Reply With Quote
Some ISP's are now blocking certain access Ports to this type of software - what ISP are you using?
SeaBass
posted on 28/5/07 at 08:22 PM Reply With Quote
Yes as mentioned some ISPs do not like P2P software as it takes up their expensive bandwidth that they buy from someone else generally. Azureus (sp?) is good as you can obfuscate the traffic so the ISP has difficulty detecting what you are doing. With Torrents you can also spec ports to something well used like Halflife.
Catpuss
posted on 3/6/07 at 03:58 PM Reply With Quote
See if you get it going with uTorrent with encryption mode enabled. If you can't get that going then there is a good chance its a problem at you end.
Marcus
posted on 4/6/07 at 11:35 AM Reply With Quote
Anyone know if Orange are blocking limewire?
Not been able to connect for a few weeks now
Marcus
Because kits are for girls!!
