Confused but excited.
| posted on 4/6/07 at 09:25 PM |
HELP!
I have not yet reached that part of the learning curve that deals with fuel injection systems, so...
I have just aquired a Renault Espace ('93). It is fine in every respect except that on start-up it ticks over at 2000/2500 rpm and rising, then
stabilises at about 3000 rpm. It should be 800 rpm give or take 25 rpm.
Question; Is it likely to be the ECU, or a sensor, such as Lambda, Mass air flow etc.
What I really want to know is; is it something I could sort myself or is it a stealership jobby? (Emphasis on the 'jobby' )
Any helpful, or failing that funny, suggestions would be appreciated.
DIY Si
| posted on 4/6/07 at 09:32 PM |
Does it have anything as simple as a throttle stop on it? Or something else allowing the throtlle to not shut? If not, maybe a faulty idle control
valve?
Sun Tzu, The Art of War
Chippy
| posted on 4/6/07 at 10:01 PM |
Ah! Rob, beat me to it, thought that might know the answer, (and "appear" inteligent). As said I would check for an air leak first,
wouldn't take much to up the rev's. HTH Ray
| posted on 5/6/07 at 11:05 AM |
Cheers guys! All the help is really appreciated.
We n'er 'ad this kind o'trouble wi' steam.
