nitram38
| posted on 28/7/07 at 09:58 PM |
WWII V1 Doodlebug found in Canary Wharf!
Tonight I am at work
600 yards from a WWII BOMB !
I have been wondering how to fit some wheels on it and get it through sva all night !
Hopefully I will still be here in the Morning
BBC NEWS LINK
[Edited on 28/7/2007 by nitram38]
caber
| posted on 28/7/07 at 10:03 PM |
Pulse jet needs airflow to get started. V1 s were fired from a giant catapult to get them going! Mind you its an interesting alternative to NOS for
that extra bit of acceleration!
Caber
Blakey_boy
| posted on 28/7/07 at 11:07 PM |
Doubt if it will pass the SVA noise test
Gene Hunt:- If anything happens to that car, I'm coming round your house and stomping on your toys, Understand?
nitram38
| posted on 29/7/07 at 04:52 AM |
No, but it might pass Croydon if it goes off!!!!
Browser
| posted on 29/7/07 at 09:42 AM |
quote: Originally posted by caber
Pulse jet needs airflow to get started. V1 s were fired from a giant catapult to get them going! Caber
S' a myth apparrently (the bit about pulse jest needign airflow to start), according to
Wiki anyway. They need the cat/assissted launch due to their flight characteristics.
nitram38
| posted on 29/7/07 at 10:04 AM |
They also used the ramp to aim them!
martyn_16v
| posted on 30/7/07 at 10:25 AM |
Pulse jets do need airflow to start, but I can't see any sane (or even mildly insane) person relying on hurling a big bomb through the air to do
it. If it doesn't catch then someone a couple of hundred metres downrange is going to have a bad day...
| posted on 30/7/07 at 10:30 AM |
At a guess, they probably used compressed air to get the process going. Once they're running they'll keep going, even when stationary.
I've seen a R/C model Blackbird that used 2 pulse jets - now that was NOISY!
iank
| posted on 30/7/07 at 10:32 AM |
They were definitely lit before being sent up the ramp that's what provided the power for lanch.
The reason for the ramp was partly to aim, and partly to avoid the need for an undercarriage (you can see the launch trolley falling away in this
film)
http://www.youtube.com/watch?v=UgpnKARvd24
You can hear one on this launch
http://www.youtube.com/watch?v=YIzr0iTZe_E
[Edited on 30/7/07 by iank]
Anonymous
smart51
| posted on 30/7/07 at 10:36 AM |
They made a pulse jet powered gocart on Scrapheap Challenge once. I seem to recall that they started it with a leaf blower.
The engine that they made was basically a U shaped pipe with propane being fed into the bend. A spark plug fired the fuel causing a big bang that
sent the exhaust out of both ends of the tube, creating thrust. The speed of the exhaust gasses caused a vacuum in the pipe, sucking in clean air
into the tube where the propane was being fed and the whole lot sparked again.
it was LOUD. Very, very loud. It glowed orange and it went quite well too.
[Edited on 30-7-2007 by smart51]
