Author: Subject: espace vibration problem
richard thomas
posted on 9/8/07 at 06:41 PM Reply With Quote
Hi all, anyone work for Renault?
I have a 2004 espace 1.9dci. It has developed a wobble/vibration when accelerating or under load from 45-55mph, not through the steering wheel but the whole car seems to be shaking side to side quite noticeably. Bit like a wheel imbalance but only when under load...doesn't do it when cruising/decelerating from 55-45mph.
I'm thinking engine mount or driveshaft or something? It isn't affected by engine rpm, only roadspeed, so i've discounted the flywheel/clutch.
Any ideas/suggestions?
Rich.
[Edited on 9/8/07 by richard thomas]
caber
posted on 9/8/07 at 06:53 PM Reply With Quote
My experience with renaults dates back a long long time but what you describe sounds like a drive shaft failure possibly the CVJ breaking up! This used to happen depressingly regularly on the 16TS, 15TS and 18TS I owned in the 70s and early 80s ( I did say it was a long time ago!)
Caber
richard thomas
posted on 9/8/07 at 07:51 PM Reply With Quote
have had a crawl under the car and there doesn't seem to be any play in the joints....
ch1ll1
posted on 9/8/07 at 08:18 PM Reply With Quote
hi check and make sure the balance shaft has not moved on the drive shaft !
richard thomas
posted on 9/8/07 at 08:29 PM Reply With Quote
thanks - couldn't see one earlier, but it has all of the undertrays fitted - i'll have a better look tomorrow.
