Author: Subject: Plumbing - Fitting an expansion vessel
Surrey Dave
posted on 16/8/07 at 05:45 PM Reply With Quote
I've just fitted a cond /combi boiler and the instructions state that if you have a water meter , which in turn has a non return valve you must fit an expansion vessel in the main cold water feed to the boiler.
I have bought one with a fitting kit which has a gauge filling loop etc, I dont understand why i need a filling loop as it is going the main water pipe anyway via a tee piece, how do i connect it and remove the air?
it is set at 2 bar from standard although it has a schraeder valve for adjusting.
[Edited on 16/8/07 by Surrey Dave]
Surrey Dave
posted on 16/8/07 at 05:48 PM Reply With Quote
kit
why have i no option too upload a photo?
ruskino80
posted on 16/8/07 at 05:59 PM Reply With Quote
filling loop is supplied as the normal use for an expansion vessell is on the heating side.disregard it and just t in the vessel as it is only going to act as a buffer/damper to the cold mains.
MkIndy7
posted on 16/8/07 at 06:02 PM Reply With Quote
I'd guess without the pic that the flexible hose is for connecting the Vessel to the pipework, if the vessel is say mounted on the wall and the pipework is flush with the wall.
Any valves or drain-offs will be so it the Vessel can be Changed should it fail or periodically be serviced/recharged.
caber
posted on 16/8/07 at 09:02 PM Reply With Quote
Must be able to figure out a use for a nice flexi on the locost, maybe for heater or header tank
Caber
