New Topic New Reply
Author: Subject: Caterham type rear and panhard rod.
goodguydrew
posted on 11/9/07 at 11:39 PM Reply With Quote
Hi all,
I am planning to deviate from the Champion book rear chassis design. I would like to make RU1&2 horizontal, with a kick up behind X2. I think this might give me a problem with the panhard rod moving further off the horizontal.
Does anyone have an advice or helpful pictures?
Thanks, Andrew.
SkinnyG
posted on 12/9/07 at 06:15 AM Reply With Quote
I would do the same thing you are thinking. Much nicer look.
My panhard is mounted even with the bottom of the chassis - and those tubes get in the way. If I ran them horizontally, as you're thinking, it would have been a lot easier, though the bar would have to be a touch higher to clear.
A solid axle Lotus has the rear roll center mounted quite low, too.
G
[Edited on 12/9/07 by SkinnyG]
The Lethal Locost
goodguydrew
posted on 12/9/07 at 10:12 AM Reply With Quote
Thanks for the picture. It's very helpful. Does anyone have other similar pics? Thanks.
posted on 13/9/07 at 08:34 AM Reply With Quote
Be aware fitting the pahard rod so low will lower the rear roll centre.
mawmaw
posted on 6/10/07 at 07:48 PM Reply With Quote
just make sure your front roll centre is lower otherwise you'll be in doodoos
New Topic New Reply
