Author: Subject: Flywheel weight
novacaine
posted on 14/9/07 at 05:39 PM Reply With Quote
Flywheel weight
what is the rough weight and dimensions of a pinto/cvh/xflow flywheel?
im building an electric race car in school and im trying to make a KERS for it using a car flywheel,
i could do with knowing the dimensions and weight of the average flywheel to work out how fast it should spin to hold the energy required,
whats the going rate for a flywheel at a breakers?
cheers people
help much appriciated
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
oadamo
posted on 14/9/07 at 05:44 PM Reply With Quote
http://www.youtube.com/watch?v=-xitMWUfeLk
adam
blakep82
posted on 14/9/07 at 07:31 PM Reply With Quote
________________________
whitestu
posted on 15/9/07 at 08:16 AM Reply With Quote
cvh 1.8 is about 6.5 kg. I can measure the size if you want.
Stu
