Author: Subject: connecting blade loom to sierra
marcotuinenburg
posted on 7/10/07 at 08:54 AM Reply With Quote
I can't get out of this problem.
Have used a diagram from hellfire and a nice drawing from an other user on this forum but still don't know how to wire it.
There is a grey wire coming from the turn signal relay.
But how do i have to wire it to the Sierra indicators.
I tried to connect it to the black/red and black/white and but where do i have to wire the black wire ?
It says switched + VE supply but i don't know what that means.
Hope someone can help me with this.
Thanks, MarcoImage deleted by owner
posted on 7/10/07 at 09:11 AM Reply With Quote
Which flasher relay are you using? A switched + wire is one that is only live when the ignition is on in the engine running position and is black in a Ford loom. Permanent live is on all the time and is red in the Ford loom.
marcotuinenburg
posted on 7/10/07 at 09:37 AM Reply With Quote
I'm using the original flasher relay coming from the 1999 fireblade loom.
There are going 1 green/white, 1 green and one grey wire coming out of the relay.
