bigandy
| posted on 10/10/07 at 09:37 PM |
Linear motion component sources.
Evening folks.
I'm currently working on a personal project to build a CNC hot wire cutter, for cutting EPS foam.
I have a few design concepts, that all use different types of linear motion parts, and I need to decide which one to go for. One design uses round
rail and linear bushings (either ball, or just plain bushes), another design uses rails and the trollies that mount to them, and another uses slide
guides.
I was just wondering if anyone can recommend a decent (cheap, and good quality!) supplier of all things related to linear motion components, such as
ball screws, acme lead screws, linear bearings, slide ways etc etc.
I'm already looking at a company called Misumi, who we use at work, and I have also seen a company called Marchant Dice. Any others?
Dammit! Too many decisions....
oadamo
| posted on 10/10/07 at 10:04 PM |
rs sell just the things you need they sell a load of diffrent ones but heres a few numbers to help your search.
linear bearing part no.lsag5c1r100
lead screw part no.756-056
roller ball screw part no.267-5870
adam
oadamo
| posted on 10/10/07 at 10:07 PM |
i have used them there very good i made a cnc bed to hold a plasmer gun head but that was a few years back.
adam
short track 123
| posted on 10/10/07 at 10:30 PM |
do you have any pointers on building a cnc plasma cutter as I am just about to make one.
did you stepper motors if so where did you get the drivers from any where in the uk?
Jason
nasty-bob
| posted on 11/10/07 at 04:53 AM |
Merchant Dice on ebay seems to be pretty reasonable.
Let us know how you get on- I'm sure there are a few of us that would be interested to hear about it.
MarchantDice
| posted on 11/10/07 at 08:41 AM |
CNC Components
Marchant Dice Ltd are manufacturers of desktop CNC machines not just resellers.
A wider range of products with discounts are available via our E-shop www.worldofcnc.com
For build issues and technical support try our Blog http://www.marchantdice.com/forum/
[Edited on 11/10/07 by MarchantDice]
