Author: Subject: Delayed Audio
speedyxjs
posted on 12/10/07 at 08:54 AM Reply With Quote
Delayed Audio
What can i use to correct delayed audio on a video?
Benzine
posted on 12/10/07 at 09:21 AM Reply With Quote
Watching on your pc? Could try and download divx player/download some codecs
[Edited on 12/10/07 by Benzine]
gingerprince
posted on 12/10/07 at 09:27 AM Reply With Quote
If you use a clever arrangement of mirrors such that the picture goes all the way around the world, then by the time it gets back to you 1/7 second will have passed so bringing you closer to the audio. Simply reflect it round the world the requisite amount of times to negate the delay you're experiencing...
Sorry, that friday feeling
graememk
posted on 12/10/07 at 09:29 AM Reply With Quote
stand further off and turn the sound up. very locost.
Ivan
posted on 12/10/07 at 09:49 AM Reply With Quote
The answer is put a Jag engine in it - now what was the question again?
speedyxjs
posted on 12/10/07 at 12:06 PM Reply With Quote
Tried that. PC wasn't big enough
Ivan
posted on 12/10/07 at 01:47 PM Reply With Quote
The answer to your question (given my limited knowledge) is there is not much you can do with your existing setup as its a processing power problem.
A complicated workaround would be to get a video editing program that will allow you to move the soundtrack relative to the image - but the result will always be only relevant to your machine
chriscook
posted on 12/10/07 at 06:28 PM Reply With Quote
You might be able to correct it with a setting or two in your playback software - but then I'm using Linux not windows so am not familiar with Media Player. Perhaps try a different player?
