cadebytiger
| posted on 15/10/07 at 10:04 PM |
Computer started on its own?!? any experts?
Sorry it's off topic up my friend's PC started in the middle of the night last night from a full shutdown - no spooks that we are aware
of. lol
It then turned off and on and off and on - just powering down (not shutting down).
At first it got to the login prompt but began to get less and less far into the startup before turning off again.
She had to pull the plug and now will not start up at all.
Anyone got any ideas? I build my own PC so have basic knowledge ut don't really know where to start here.
Any ideas? Thanks again
Rupert
[Edited on 15/10/07 by cadebytiger]
| posted on 15/10/07 at 10:09 PM |
Depends upon the board type. An ATX uses a relay (via on/off) to boot. Maybe connection to the board or the actual button itself is faulty. Remove the
on/off button connector and see if the problem recurrs. If all is ok - there is your problem, cheap fix. That would be my first POC.
[Edited on 15-10-07 by Hellfire]
Dangle_kt
| posted on 15/10/07 at 10:11 PM |
it on a LAN? Some MB have onLANwake up? Maybe the motherboard is having a bad day. if so unplug LAN and try again.
It wont be the PSU, the RAM, the HDD, the processor or the graphics card - so I'd start by swapping out the case (maybe a faulty front button)
then the MB in case of a faulty conection on the MB with the front switches.
RazMan
| posted on 15/10/07 at 10:12 PM |
I think some BIOSs have options to turn the system on automatically - worth a look anyway.
Either that or its haunted
Raz
Dingz
| posted on 15/10/07 at 10:16 PM |
A friend had a similar problem, tracked itdown to a faulty reboot button.
Scoob
| posted on 15/10/07 at 10:37 PM |
Mine had that problem about 3 months ago, didnt do anything about it, now it crashes all the time with a " boot problem" or summat, and
then last week it caught fire in the middle of the night :\
So my advice, what ever it is, get it sorted just incase lol
graememk
| posted on 15/10/07 at 10:43 PM |
either faulty button (unlikly)
faulty psu
or lan/modem wakeup coming on for some reason.
Simon
| posted on 15/10/07 at 11:10 PM |
Mine was swithcing itself off with alarming regularity - between 0 secs and 5 to 10 mins (but not on). A friend threw in another power supply unit (as
Graememk mentioned), and (touch wood!!!!!) it's been fine since.
Simon
[Edited on 15/10/07 by Simon]
donut
| posted on 16/10/07 at 07:44 AM |
C'mon guy's you know what the problem is...... It's Haunted!!
