Fred W B
| posted on 24/10/07 at 06:09 PM |
Crazy? German
What do you think? Crazy? german
He says "it was logged at 229,74 km/h by GPS- at the End of the "Parabolica" at Hockenheim-Ring Racetrack this Year...;-)
The main Drawback till now are the Brakes. The Kart is ready to drive at a total weight of 208 kg (458 lb) + Driver about 70 kg (187 lb)...that is
about 50 kg (134 lb) more then an actual Superkart.
This is resulting in much earlier Brakepoint comparing to a Superkart and directly lower Laptimes.
I drive Hockenheim in 1:52, best Superkarts are at 1:43 ...
Fred W B
[Edited on 24/10/07 by Fred W B]
blakep82
| posted on 24/10/07 at 06:13 PM |
________________________
pajsh
| posted on 24/10/07 at 07:04 PM |
Looks like it could do with bigger back wheels.
If you use the Elf Tyrrell as a yardstick the rear wheels are probably three times the size of the front.
Post it to Top Gear and see if he can beat the Ultima.
I used to be apathetic but now I just don't care.
novacaine
| posted on 24/10/07 at 08:49 PM |
i thought Parabolica was the last turn of monza....
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but
your older, shorter of breath and one day closer to death
blakep82
| posted on 25/10/07 at 07:18 AM |
yeah!
ditchlewis
| posted on 25/10/07 at 07:36 AM |
