danro
| posted on 25/10/07 at 08:12 AM |
help! low oil pressure in Vaux corsa
Hi guys, not quite a locost but following the same ethics
I have a 1.5TD corsa on an "L" plate.
On the way into work today the oil lamp came on
It stayed on at ilde but as soon as I pulled away it went off.
At the lights, if I reved it, it would stay on, so pressure was only there under load?
As soon as the load came off the engine the light came on again.
I checked the oil level - about half way between min and max, and that was straight after a drive so hot and loads around the engine.
Any ideas? Oil pump? is it a big job
cheers for any help
Danro
davie h
| posted on 25/10/07 at 08:24 AM |
is there a rattle from behind the timeing belt covers the oil pump runs off the timeing belt and there was a problem with the pulleys coming loose on
the oil pump shaft
danro
| posted on 25/10/07 at 09:08 AM |
Cheers Davie h
I did not notice any extra rattles, the only ones I currently have are road related ones and not engine ones
danro
| posted on 25/10/07 at 09:34 AM |
When the lamp is on, it is more of a flicker and the flicker speeds up with the revs could it be a duff sensor?
How would I test it?
| posted on 25/10/07 at 09:46 AM |
If it happed on my crossflow I'd check the oil pressure relief valve on the oil pump, which gave exactly that symptom when it was stuck open.
I don't know if there's an equivalent thing on the Corsa.
| posted on 25/10/07 at 10:10 AM |
I'd swap the sender first, if it's got a bit of swarf in it it will stop working. They are usually only a fiver at most from a parts
shop.
[Edited on 25/10/07 by Peteff]
adithorp
| posted on 25/10/07 at 03:35 PM |
check that the wire hasn't rubed through to earth on something.
adrian
| posted on 25/10/07 at 06:18 PM |
Probably the sender as already suggested, I would do an oil pressure check to be sure.
