Howlor
| posted on 25/10/07 at 10:14 PM |
Try this!
Link
86% Rushing and tired!
scoobyis2cool
| posted on 25/10/07 at 10:43 PM |
88% for me Right, that's worn my brain out, bed time I think!
Pete
| posted on 25/10/07 at 10:50 PM |
98% grrr, I was robbed on the gear drive question. I'm sure the test is incorrect
dave1888
| posted on 25/10/07 at 10:58 PM |
78%
cloudy
| posted on 25/10/07 at 11:00 PM |
96% at a rush, 50 questions is quite boring!
Paradoxia0
| posted on 25/10/07 at 11:15 PM |
78%!!!!
I think that is good as I only learnt how a sanner worked 6 months ago
There is no replacement for displacement...
eccsmk
| posted on 26/10/07 at 12:06 AM |
80% go me lol
Macbeast
| posted on 26/10/07 at 02:38 AM |
88% at 3 am
jollygreengiant
| posted on 26/10/07 at 04:53 AM |
88% at 5:53am
thepest
| posted on 26/10/07 at 05:22 AM |
90% at 7am
wilkingj
| posted on 26/10/07 at 08:04 AM |
Grr... 86% only average
Interesting that at least I could get a job as an apprentice mechanic.
Still I would not want to wear the white shirt and use a computer all day chaning parts that a computer tells me to... No skill in that at all.
Best Regards
Geoff
http://www.v8viento.co.uk
gingerprince
| posted on 26/10/07 at 08:16 AM |
86%. Strange that I only got 1 "correct" popup, almost as if that question was particularly hard and you deserved a popup
twybrow
| posted on 26/10/07 at 08:21 AM |
86% when I should have been doing work....
I didn't like the planetary gear questions...
cadebytiger
| posted on 26/10/07 at 08:30 AM |
84% not 100 but not too bad
martyn_16v
| posted on 26/10/07 at 09:07 AM |
92%
| posted on 26/10/07 at 09:36 AM |
84% hmm, not sure all t he answers are right.
matt_claydon
| posted on 26/10/07 at 10:34 AM |
100%, although I did have to make a couple of fan blades out of post-it notes for the fan one!
COREdevelopments
| posted on 26/10/07 at 10:56 AM |
show off! 84% i had. did rush a bit. good find though, enjoyed it.
robertst
| posted on 26/10/07 at 11:21 AM |
80% with a hangover.... who can beat that?
Tom
roadrunner
| posted on 26/10/07 at 12:35 PM |
Did seven questions ,then realized that there where fifty to do so switched off with boredom.
vindicator
| posted on 26/10/07 at 02:20 PM |
got 74% failed, I'll just keep working with computer software.
omega 24 v6
| posted on 26/10/07 at 03:37 PM |
90%  But a good quiz.
Got the fan one wrong. It's a bit of a trick one as it is (in relation to the fan in it's own entity) going in the opposite direction.
never read the a and b tube with fluid question thoroughly (twat)
The piston one ???? What happened to suck squeeze bang blow SUCK SUCK
And the gear one?? 2 out of 4
And the pulley one (twat again)
[Edited on 26/10/07 by omega 24 v6]
So 500 lines for forgetting my formulae from 30 years ago  And if I get them wrong next week it'll be 1000 lines. AH THE GOOD OLD
DAYS
cossey
| posted on 26/10/07 at 03:45 PM |
96% the 2 i got wrong though were the 2 desk fans one and the what causes air to move into the cylinder which is a semi trick question as the correct
answers is a pressure gradient which means either b or c if correct
Liam
| posted on 26/10/07 at 04:57 PM |
Exactly - both answers correct!! And if you wanted to be pedantic you could argue that the piston moving is the primary cause of the pressure
differential, and the air being 'pushed' in by atmospheric pressure happens as a result of that - so the piston answer is better .
Also got the gear ratios wrong swapping direct and reverse - stoopid question humph, and the water tubes one (which, working in fluid engineering,
there's no excuse for!). 94%
Liam
t.j.
| posted on 26/10/07 at 05:25 PM |
84% forgotten some english words like: naturally aspirated ???
I hate the lift things, were sleeping the day that past in the lesson
