Andybarbet
posted on 28/10/07 at 07:50 PM |
Corsa Cutting out problem ??? Help !!
Ok peeps,
My girlfriends 1.2litre injection - 8valve 'R' reg corsa keeps cutting out, whilst driving. Generally before its fully warmed up and then
it normally wont start again for a while, if it does start again, the revs are all over the place and the engine management light is on
frequently....it cuts out as you come up to junctions occasoinally too.
Ive been told it is likely to be the air idle control valve but what do you reckon ??
I can get one for 30 quid and its easy to change but am afraid it might not be that and 30quid down the drain right now, i could do without !
Also, a neighbour said its the map sensor ?? would these be the symptoms if this was playing up ??
Thought i would check on here before i start replacing bits that i cant afford.....
Cheers in advance.......Andy
thunderace
| posted on 28/10/07 at 09:55 PM |
have a look at the hose i have seen a number that have cracked letting in air its a common fault ,when changing the air filter they bend the rubber
pipe spliting it .
seen it loads of times.
cjtheman
| posted on 28/10/07 at 10:30 PM |
i had same problem on 16v 1.2 corsa
on mine it was the crank sensor
hope that helps
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
Scoob
| posted on 29/10/07 at 12:41 AM |
AFAIK the MAP Sensor controls the idle speed, So could be that? Kicking in at the wrong times etc, therefore making it rev more frequently?
Im not 100% sure though..
procomp
| posted on 29/10/07 at 07:51 AM |
Hi in 99% of cases it is ussually the idlde control valve. Most times if you remove it give it a clean and refit it's ussually ok.
A new one if required was i think about £27 but may varry depending on different models. Have had to do them on most family and friends vaxhauls over
the years.
HTH cheers Matt
Andybarbet
| posted on 29/10/07 at 09:09 AM |
Ok chaps,
Ive checked the hose that thunderace mentioned but no signs of damage there, would have been the cheapest fix i think....
I have taken the idle control valve out before and cleaned it up, seemed to improve things for a week or so but its got worse again so think i will
get a new idle valve for it and keep me fingers crossed.a friend had the same problem with a cavalier and changing the idle valve has transformed the
car apparently.
If that doesnt improve it i will try to pick up a map sensor from a scrappy, thanks for the advice, will let you know if this sorts it out..
Cheers....Andy
nathanharris1987
| posted on 29/10/07 at 11:28 AM |
my old corsa did that, was a 1.4 however with the same symptoms. changed the distributor cap and it was ok for a while, then after about a month, same
problem again and needed a new distributor.
