Author: Subject: What master cylinder to use for a blade 06
mangogrooveworkshop
posted on 30/10/07 at 07:39 PM Reply With Quote
Any bright sparks care to tell us what master clutch cylinder to use for this beasty
jambojeef
posted on 30/10/07 at 11:22 PM Reply With Quote
Post up a piccy of the slave then?
If its the 3 bolt mounting round and flat slave one that Ive seen on every Honda with a hydraulic clutch (that only being CBRs and VFRs mind) I can recommend one to you?
Geoff
beppesignori
Contributor
Posts 82
Registered 7/8/06
Member Is Offline
Photo Archive Go!
Building: MK Indy Sold. Contemplating V8 midi scratch build
posted on 9/12/07 at 11:09 PM Reply With Quote
This is the one in question. Its from a 2006 CBR 1000 RR. Housing slightly modified to accomodate propshaft. Would appreciate any suggestions as to which master cylinder to use(apart from the one from the bike).
Tx
Gave up trying to attach pic. Its in my Archive....
[Edited on 9/12/07 by beppesignori]
