graememk
| posted on 5/11/07 at 05:46 PM |
tow bar, where to buy from and what make
i want a tow bar for a 57 plate vectra.
but one that you can take off, are they called swan neck or something ?
also the electrics as the vectra has "canbus" electronics that detect a bulb out and you need a special loom or something
anyone got a cheap contact ?
omega 24 v6
| posted on 5/11/07 at 06:17 PM |
I've got a "Brink" one on my Omega with a removeable swan neck. Very sturdy and well made. For the electrics you'd be better
using a 7 way bypass relay from the likes of towsure.
Edited to say that if you use the "Special loom" then you need the tech2 on it to set up the trailer indicators I believe.
[Edited on 5/11/07 by omega 24 v6]
Danozeman
| posted on 5/11/07 at 06:44 PM |
Theres a choice. Swan necks you can just unbolt, or a proper removeable that kind of unclips.
I have used this place a few times. Very good. You will nee a special wiring
loom for it.
Have you had any quotes from indespenion and the likes for supply and fit?? Theyr not too bad and only need the car for a couple of hours max.
[Edited on 5/11/07 by Danozeman]
Dan
jacko
| posted on 5/11/07 at 07:16 PM |
Look up towsure tow bars
NS Dev
| posted on 5/11/07 at 09:39 PM |
I recently used a company that manufactures and deals direct, cos they were very close by, but still another possibility I suppose:
http://www.ankertowbars.co.uk/
mine wasn't detatchable or owt but at under £60 for a BMW 7 series i thought ti was pretty good value!
[Edited on 5/11/07 by NS Dev]
