Mark Allanson
posted on 27/9/03 at 08:53 PM |
Web cams
This is definately 'anything else'!
Number one daughter is at uni in bristol, and we have just discovered MSN Messenger - it has a web cam feature so I am going to get a pair of these,
and send one up to her.
A few questions . Do they have microphones? If not will any microphone plugged into the sound card work? Any to avoid - recommend?
Can you talk face to face with them?
Mark
eddie
posted on 27/9/03 at 09:18 PM |
within reason you can plug any mic in, but it would probably be easier to invest in a headset mic made for use with a 'pooter (less chance of
feed back)
this is just from my own experiance so others may know better.....
Please feel free in advance to: correct, update, ridicule or laugh and point at any comments made by myself in this post....
Noodle
posted on 27/9/03 at 09:28 PM |
I use webcams from my work connection to home (ADSL broadband). I get around 5 frames per second broadband. It's very good and will get through
a completely anal work/university firewall whereas previous versions screwed up.
I haven't used the audio facilities yet, but an informed source tells me there is a latency issue. It's like speaking to someone on the
moon! I stick to typed text. I should get a (free) headset next week, so I'll be trying myself. I'll keep you posted.
Neil.
flyingkiwi
posted on 27/9/03 at 09:45 PM |
I use the headset when playing online games, with msn I've never had a problem with delay, unless your chatting with someone running a slower
connection, then you can end up with two conversations at once.
If you use a normal mic on a stick you'll find the feedback from the speakers is hard going, you'll hear what you said two seconds
later.
I recommend getting a deceint webcam, my first one was cheap and it showed. I use it alot to chat with people back in NZ. Save's loads on phone
calls
Chris
[Edited on 27/9/03 by flyingkiwi]
It Runs!!!!! Bring on the SVA!
