cadebytiger
| posted on 18/11/07 at 01:52 PM |
306 MOT fail on brake light problem
Hey there.
Sorry this is a bit off topic but the kit in the garage now and i have gone back to using my pug 306.
It has just failed it's MOT because when the indicators are switched on with the brake light on also the brake light dims with each flash of the
indicator.
I am thinking it sounds like an earth problem but the light cluster earth wire runs off into a bunch of wires and then god knows where it goes.
I have cleaned up tow earths in the engine bay to no effect.
Any ideas would be more then welcome!
Thanks again
Rupert
Danozeman
| posted on 18/11/07 at 01:54 PM |
Clean up the earthing points in the boot and the contacts on the light cluster. IIRC there are some on the reare panel and up near the strut tops.
Dan
dan__wright
| posted on 18/11/07 at 02:08 PM |
rear lights will be full of water causing a short, common problem, also happenes on the 106.
take but bulbs / holders out and test again, will work fine.
empty lights out and drill a few smal holes on the bottom for water to drain
| posted on 18/11/07 at 02:19 PM |
After cleaning the rear light cluster terminals I would also run an additional earth wire for each rear light.
Kook
| posted on 18/11/07 at 02:27 PM |
I added a earth point to my old 306 when it was doing the same and connected new wires to the new earth point and it was ok after this.
| posted on 18/11/07 at 03:17 PM |
It can happen if you force a stop and tail bulb in the wrong way round as well.
cadebytiger
| posted on 19/11/07 at 05:41 PM |
thanks for all your help
I have made new earths for both sides and they are good. This has sorted the left side but right i still playing up.
Tryed cleaning the connections *no water in there BTW) but still no joy! I will check the bulb types tonight
Thanks again
Rupert
