chrsgrain
| posted on 22/11/07 at 08:06 PM |
Garage heater - which one?
OK guys...
its definitely getting colder and we need a garage heater - have dry lined the walls and put in a plasterboard roof with loft insulation above it -
and put polystyrene on the metal door...
Any ideas which one? Don't want a gas one, had that before and it made loads of condensation... just need one big enough to keep SWMBO warm !
Chris
mookaloid
| posted on 22/11/07 at 08:11 PM |
Those electric infra red ones kick out a fair bit of heat
Mark
Bluemoon
| posted on 22/11/07 at 08:16 PM |
I like my IR one (8quid so might be worth a shot) Have to be close to it though. Nice thing is that you don't heat all the air up and it's
very much instant heat.
But if you want to space heat the whole garage you might need something else.
Dan
MkIndy7
I'm sure you've just forgotten to mention it.. but I presume you've got something covering the floor?.
I've always thought fan heaters were pretty good as you could direct them towards you where your working.
caber
| posted on 22/11/07 at 08:25 PM |
Work harder work faster, use hacksaw and files instead of angle grinder wear long johns under trousers and a proper wooly jumper under the boiler suit
SWMBO would look nice in wooly jumper and ski pants
Caber
| posted on 22/11/07 at 09:53 PM |
I don't like fan heaters. They blow the cold air around whilst giving off very little heat. Also they suck bits of angle grinding into the
element which then fuses with a bang. I'd recommend an oil filled radiator (I've got a Delonghi Dragon) or for the Scottish out there, a
Dickies thermal worksuit and a Thinsulate beanie hat!!
thunderace
| posted on 23/11/07 at 12:58 AM |
Dan
where do you get a infra red heater for £8????
Bluemoon
| posted on 27/11/07 at 01:35 PM |
Look in the "discount" type stores... Loads of them about..
Dan
DarrenW
| posted on 27/11/07 at 01:40 PM |
I use a IR heater and a fan heater to help distibute heat about. worked very well in a 13' x 29' garage that i used to have a when
building.
