Author: Subject: Tintop strut brace!?!?
tegwin
posted on 19/12/07 at 10:54 PM Reply With Quote
One of the other car specific forums I frequent is full of people going on and on about how they are fitting strut braces to the front and rear of their front wheel drive hot hatch....(along with some other pointless bits and pieces of heavy metal)
Now, I know the theory of them is to prevent flexing between the suspension mounts to give a crisper ride with sharper handling etc...BUT
If the flexing without a brace was so bad as to effect the suspension enough to be noticed wouldnt this cause the car to fall appart due to excessive fatigue stressing of the metal?
And...Because the suspension arms are mounted on nice squidgy bushes, adding a strut brace would do diddly squat because the suspension arms can still flex in a direction that is not beneficial to the cars performance...
So are strut braces really an aid...or are they just another one of those "go faster" "shiny" cons...
I know they are fitted as standard to at leas t one production car...Either the rx8 or the 350Z...I cant remember which, seemed a bit odd...
Just one of those random questions that i figured I should share with the world...
blakep82
posted on 19/12/07 at 10:57 PM Reply With Quote
well... they use them in mk1/2 escort rally cars and the like. i doubt they're much use on road cars though
________________________
indykid
posted on 19/12/07 at 11:57 PM Reply With Quote
i know 2 people that have fitted them.
both noted it increased the car's tendency to understeer. this was a mk3 astra and a 106.
the one with the astra took it off again within a couple of hundred miles, the one with the 106 gti left it on for the look, but to be fair, he never really drove it hard except in a straight line.
not a road car mod i guess, and not ideal if used on its own
tom
MkIndy7
posted on 20/12/07 at 12:22 AM Reply With Quote
I think in FWD they might be a bit of cosmetic gimic as well, if its got Front anti-roll bars then it should be enough.
My 170 BHP 1988, Opel Corsa understeers less than my 1995 55 BHP 1.1 MK3 Fiesta Sapphire ever did with the same size tires!.
Mr Whippy
posted on 20/12/07 at 01:33 AM Reply With Quote
you'd be suprised just how much some cars flex, you won't don't tend to notice unless the car has a forward opening bonnet. I've seen the bonnets move around at the top when open and the wheels are turned from side to side
carpmart
posted on 20/12/07 at 07:39 AM Reply With Quote
I had an old e30 BMW 325i 2 door. Now admittedly this is RWD so doesn't directly answer your question but, I fitted one and transformed what was already good handling to great handling. I am not sure if that was due to the car being 22 years old so a bit 'looser' than it should have been but it did make a significant and worthwhile difference.
I've sold that car now
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
mcerd1
posted on 20/12/07 at 08:52 AM Reply With Quote
anything that stiffens the chassis has got to help
but I suspect that you'll also need to adjust the suspension to make use of it as well as pollybushes etc
(followed by lots of testing/ setup)
my 106 (1.0 LX) flexes so much that it would take a full weld-in cage to really stiffen it, also its got very soft bushes, soft springs, soft dampers and there is no anti-roll bar - so just fitting a strut brace would be totally pointless
[Edited on 20/12/07 by mcerd1]
irvined
posted on 20/12/07 at 08:59 AM Reply With Quote
I have both front and rear braces fitted to my MX5 (RWD Though) and i noticed a big improvement compared to not having them.
Don't know how to describe it - but its definitly sharper.
http://irvined.blogspot.com
pajsh
posted on 20/12/07 at 11:18 AM Reply With Quote
I had a 06 Mondeo ST150 CDTi last year that I'm pretty sure had one fitted as standard.
Cornered well on flat stuff but easily unsettled over bumps. Had pretty wide wheels (245 40 R17 IIRC) too which didn't help.
I used to be apathetic but now I just don't care.
dan__wright
posted on 20/12/07 at 01:15 PM Reply With Quote
ive added on to my corsa c (fwd) and it made a huge difference, the car used to understeer a lot, added the brace and its loads better, then put stiffor & shorter springs and even if i try i can not get it to understeer now.
FREE THE ROADSTER ONE…!!
MkIndy7
posted on 20/12/07 at 06:42 PM Reply With Quote
I suppose mines got lowering springs on it and its Polly bushed everywhere.
I was considering getting a strut brace for the front but its hard to find a definitive answer which (if any) will fit over the standard air box on the XE engine.
