locoboy
| posted on 20/12/07 at 04:42 PM |
lpg removal v8
I am in the process of stripping out the LPG system from a range rover V8 EFI.
There are 2 rubber hoses that go from the gas 'regulator' (i think thats what it is!) up and over the plenum and into the V of the block
at the back and i cant see what they connect to.
Any ideas?
Can i cut them off and join them together maybe?
Locoboy
paulbeyer
| posted on 20/12/07 at 04:44 PM |
That sounds like the plumbing for the hot water supply that flows around the reducer / regulator. The pipe work would have been spliced in from the
heater hose when installed so can be removed easily enough and the heater hose re-joined.
[Edited on 20/12/2007 by paulbeyer]
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
zilspeed
| posted on 20/12/07 at 08:27 PM |
Can you show us a pic of the vapouriser and mark the two pipes in question.
That will help to pinpoint it more accurately.
JF - Also an LPG user.
thunderace
| posted on 20/12/07 at 09:29 PM |
sell the engine with the lpg kit and buy a new engine as you will get a lot for it and will fund a new v8 out the box engine.
