<<  1    2  >>
Author: Subject: Running on Water
John Bonnett
posted on 23/12/07 at 12:00 PM Reply With Quote
Running on Water
I just wondered if anyone has considered modifying an engine to run on water. Plans are available I know. I thought I might buy an old engine and experiment.
John
posted on 23/12/07 at 12:10 PM Reply With Quote
I think this summer a few people experimented with water-based engines....
posted on 23/12/07 at 12:19 PM Reply With Quote
John
care to explain the science behind that? If you put water in, what comes out? I cant think of any ways of extracting usuable power from water, its already oxidised!
posted on 23/12/07 at 12:23 PM Reply With Quote
i just googled this gem
We have developed devices that use a little electricity out of your car's battery, to separate water into a gas called HHO (2 Hydrogen + 1 Oxygen). HHO, also called Brown's Gas or Hydroxy, burns beautifully and provides TONS of energy - while the end product is just WATER! Mobile Magazine says HHO provides the atomic power of Hydrogen, while maintaining the chemical stability of water.
posted on 23/12/07 at 12:29 PM Reply With Quote
It's amazing technology! You can make a fuel cell which uses the electricity in the car battery to electrolyse pure water into hydrogen and oxygen, then burn the hydrogen and oxygen to power the car engine and the engine powers the alternator which produces more energy for electrolysis....
And the amazing thing is that because all this works at greater than 100% efficiency, it's not just a rather complicated way of running a fuel powered car from electricity... In fact, at some points in the process it creates energy out of nowhere!! Amazing
mat.price
posted on 23/12/07 at 12:31 PM Reply With Quote
You extract the hydrogen from the water to run the engine on!
Yes ive been toying with the idea myself on my pinto engine but im having trouble with the wiring and stuff
Mr Whippy
posted on 23/12/07 at 12:34 PM Reply With Quote
no comment
oadamo
posted on 23/12/07 at 12:38 PM Reply With Quote
any one got any links for this.
adam
Paul TigerB6
posted on 23/12/07 at 12:42 PM Reply With Quote
adam
Are you considering it for your CBR1000 engine then Adam?? If so then i'm sure we can recommend you a site.
posted on 23/12/07 at 12:48 PM Reply With Quote
jeez...
running a car on water is just a blag, propigated partly by people's desire to avoid high fuel costs, a bit by the 'the oil companies want to stamp it out' and a bit by pipe dreams really.
The idea that you have a tank full of water, modify it and then burn it to get energy out of it is, simply, NONSENSE. Its not possible, and there are an awful lot of websites peddling pseudoscience in the hope of getting traffic and hence advertising revenue.
The first site i read spoke of electrolytically turning water into HHO gas or browns gas. This is a simple mix of H and O, as you would expect if you split water. Burning it will result in an engery out put slightly less than what you put in. Calling it Browns gas is simply a way of adding credibility, since one of the first google links about it is valid - but in a different context.
Again, PURE NONSENSE!
sprouts-car
posted on 23/12/07 at 12:51 PM Reply With Quote
You cant get more energy back from water than was used to seperate it in the first place. More energy is used in electrolysis of water than in the product (hydrogen and oxygen).
Meaning you might aswell run the car on the battery in the first place, rather than wasting energy converting the energy into another form.
Paul TigerB6
posted on 23/12/07 at 12:53 PM Reply With Quote
ah well - thats the end of the joke then i guess!! Cant see who would have seriously fallen for it now!!!
kipper
posted on 23/12/07 at 01:33 PM Reply With Quote
I had a transit that was partly running on water.......... but then I put a new head gasket on.
bonzoronnie
posted on 23/12/07 at 01:43 PM Reply With Quote
Head gasket
I had a Mk 3 escort that was the same.
Steam power. Thats what it was.
Ronnie
theconrodkid
posted on 23/12/07 at 02:20 PM Reply With Quote
well our everso eco friendly mayor,red ken has ordered some buses that run on water.
we will wait and see
who cares who wins
pass the pork pies
wilkingj
posted on 23/12/07 at 02:30 PM Reply With Quote
Agreed... Its physically impossible to get more power out that you put in.
Water injection is another matter, ie to keep the inlet / gas temperatures down, ie colder=denser, so you can pack more air and fuel in to the same volume.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 23/12/07 at 02:54 PM Reply With Quote
I've seen one of them - don't ask me what the technology is - but it was sitting at a bus-stop, whining quietly, with water vapour coming out of a vent at the back. Very odd.
I believe that this 'run on water' technology relies on electrolysis, but using square-wave pulse input. It's supposed to give more hydrogen and oxygen output than you'd get with straight DC, with far less energy input.
I have no idea whether it's true or false, so don't flame me!
posted on 23/12/07 at 03:02 PM Reply With Quote
its entirely likely that they are fuel cell buses with gas tanks on board, with the water being seperated at the local powerstation. There is some sense to this provided the efficiencies are quite high - afterall, i believe IC engines are only 14% efficient anyway. It means the 'displaced emissions' can be sent through a massive industrial cleaner/filter/catalyst at the powerstation, which may well be better than a car's normal catalytic converter.
Surrey Dave
posted on 23/12/07 at 04:32 PM Reply With Quote
Sprouts?
Eat plenty of sprouts and run on methane!!!
RazMan
posted on 23/12/07 at 04:44 PM Reply With Quote
I was reading about this a while back - you fill a plastic container with water, add a small amount of electrolyte (something peroxide I think) and apply a current across a pair of submerged contacts. You vary the current to control the Hydrogen / Oxygen generation.
There are a few manufacturers producing kits in the US - retro fitting them to cars. Amazing claims (as usual) but no conclusive results.
Personally I can't see how useful volumes of gas can be generated without installing industrial sized alternators & tanks of water.
Raz
posted on 23/12/07 at 04:47 PM Reply With Quote
I've seen a welding torch driven by an electrolysis plant that provided hydrogen & oxygen. Supposedly safe, although I have seen warnings about making your own plant - the correct 2:1 ratio of hydrogen to oxygen is pretty explosive!
posted on 23/12/07 at 05:30 PM Reply With Quote
Actually... theatres used to have spotlights powered by "lime light" which was produced when a chunk of lime is heated by a oxygen + hydrogen blowlamp.
Most early theatres had electrolysis chambers in them....
... and most of them burnt down.....
posted on 23/12/07 at 07:12 PM Reply With Quote
again, prefectly valid idea. Use hydrogen instead of acetylene. The plan being that you could have flame welding without gas tanks.
There was some debate as to whether the flame was slightly hotter than it should be, but this was very little and attributed to inaccuracies in the measurements of flame temp. So no break in the first law.
posted on 23/12/07 at 07:14 PM Reply With Quote
The different 'methods' just muddy the water, you cannot make energy. Catalysts just stabilise the transition state, hence making the reaction faster. They do not affect start or finish energy levels and they do not affect the balance of the reaction equation.
Simon
posted on 24/12/07 at 01:05 AM Reply With Quote
Accodring to the BBC Focus magazine, steam is about to make big comeback!
BR may be about to have it's first steam train and there will be a race in the states in August on (iirc) Bonneville for steam powered cars.
See
http://www.focusmag.co.uk/currentIssue.asp
Simon
<<  1    2  >>
