Author: Subject: blackbird oil cooler
thegasmen
posted on 25/12/07 at 04:29 PM Reply With Quote
i am running a dax rush with standard blackbird engine 98 carbed model and i am running the standard bike oil cooler what is the average oil pressure and temperature and has any one changed to a bigger oil cooler i am going to fit an accusump with shortend baffled sump and do some trackdays this year what do you all reccomend.
regards Mick
Aico
posted on 26/12/07 at 12:46 PM Reply With Quote
Check the temp. If it stays below 100*C then the stock cooler is fine.
thegasmen
posted on 26/12/07 at 01:09 PM Reply With Quote
oil cooler
Thanks aico ill check it next time out be glad when the weather gets better again
Jon Ison
posted on 26/12/07 at 09:09 PM Reply With Quote
I had a bird but mid mounted, I ran a 13 row cooler in the side pod, oil pressure never below 70 on anything above tick over, oil temps did get over 100 under race conditions but never on the road.
