matt.c
posted on 1/1/08 at 02:11 PM |
Gas air vent
In my bungalow we have a vent in the wall for the gas central heating. Trouble is that it is above the sofa and all you get is a really cold draft
which becomes unbearable when windy. Is there any way of stoping this? I know it has to be there for central heating but its become a real pain in the
arse! I cant move the sofa as its a fitted corner one.
Any idea's?
| posted on 1/1/08 at 02:33 PM |
I had a vent like that with my old central heating, and I know exactly what you mean. We used to have a fierce draft across the dining room! We got
rid of it by replacing the boiler with one that had a balanced flue - a bit drastic for you!
The only alternative I was considering before replacing the boiler was to duct in air via another route, probably that aluminium-coloured flexible air
trunking in the space between the ceiling and the floor above. Non-trivial.
Unfortunately you have to have the air supply...
MkIndy7
| posted on 1/1/08 at 02:57 PM |
You could try putting a 90 degree bend on the outside wall to try and turn it down or to the left or right to try and avoid the prevailing wind if it
wouldn't be too unsightly.
Or you could duct it down to a lower level internally instead.
Or as said above move it somewhere else, maybe to behind the boiler itself if thats possible, then the air goes practically straight into the burner
tray, or blows past a nice warm boiler into the room
[Edited on 1/1/08 by MkIndy7]
caber
| posted on 1/1/08 at 03:29 PM |
If you have a ventilated under floor with airbricksthen you can close up the wall vent and cut a new one in the floor adjacent to the boiler. As long
as the air bricks are clear and your new hle as about the same area as the old vent you should be OK. Get a carbon monoxide detector just to make sure
you aren't about to kill yourself though!
Caber
| posted on 1/1/08 at 03:41 PM |
Brick it up and put another in somewhere else or put a diffuser in front of it. A piece of board an inch bigger with some spacers on the screws and
fastened in front of it or hang a picture over it
| posted on 1/1/08 at 06:53 PM |
id block it up and get a CO detector.
