Author: Subject: Techy McPherson strut question.
Jesus-Ninja
posted on 4/1/08 at 08:49 AM Reply With Quote
Before anyone flames me for asking about McPherson on here, I have to admit that it's not strictly in respect to locosts, but more that I just spent the last hour or so driving to work getting my head round this to understand how my current suspension set up behaves, so that what I implement on my build is close to it, in terms of changes to angle of camber in respect to deflection of the suspension. Perhaps the Techies / Gurus can correct me if I have this wrong. OK, deep breath.....
McPherson: For the purpose of understanding changes to camber, relative to the vehicle, we can consider this to be made of 3 elements: The lower arm, the vehicle itself, and the strut, forming a triangle. All elements remain of fixed length, except for the strut, which can change length. the three elements are all free to pivot on each other. Any compression of the strut will cause the arm to rotate upwards around the point at which it pivots on the vehicle.
If the arm is horizontal at a state of rest, then as the strut compresses, and the arm rotates, the hub moves inboard. The movement inboard is therefore coupled with a change in the angle of the strut, effectively decreasing the amount of negative camber, relative to the vehicle. This is also true if the arm is angled up at state of rest - ie the pivot on the hub is higher than the arm / body pivot.
If the arm is angled down at a state of rest - ie the pivot on the hub is lower than the arm / body pivot, then as the strut compresses and the arm rotates, the hub moves outboard, increasing the angle of the strut to the body, and so increasing the amount of negative camber. Until of course the arm passes beyond the horizontal (relative to the vehicle), at which point it will behave as above.
The further the arm deviates from horizontal at a state of rest, either up or down, the more pronounced the effects described above - ie the steeper the angle of the arm from horizontal, the greater the change in angle for a given vertical movement AND the greater the movement of the hub (inward or outward) for a given angle of rotation of the arm.
Additionally, the longer the strut, the less compression, proportional to it's length, so the less change in angle from it's position at rest. And vice versa.
Have I got this right?
[Edited on 4/1/08 by Jesus-Ninja]
JAG
posted on 4/1/08 at 09:02 AM Reply With Quote
Yes, that's the basic kinematics of the MacPherson strut.
As I'm sure you have guessed though - that is JUST the basics. The individual design of each of the three elements can have an influence on the behaviour you describe.
Justin
matt_claydon
posted on 4/1/08 at 09:08 AM Reply With Quote
Sounds pretty much spot on. Not a hard job to draw out the elements and create an equation for camber in terms of strut compression.
Howlor
posted on 4/1/08 at 09:22 AM Reply With Quote
So in theory if you have much longer bottom arms the change in camber will be much less?
bimbleuk
posted on 4/1/08 at 09:26 AM Reply With Quote
A simple straight forward suspension setup used by many manufacturers. Then Toyota for example go and make it all complicated!
Superstrut suspension
I had this on a late Celica FWD car and it did make a fine handling car but I knew how much of a pain it was to service so I sold it before anything broke
procomp
posted on 4/1/08 at 09:38 AM Reply With Quote
Hi this sort of replacment mounting for the top of struts is often used for tweeking camber settings on strut setups.
Cheers Matt
Dusty
posted on 4/1/08 at 10:06 AM Reply With Quote
The camber angle is usually dependant on the Mac strut angle and isolated from the lower arm angle by some form of ball joint. They usually have a very long theoretical swing axle.
[Edited on 4/1/08 by Dusty]
matt_claydon
posted on 4/1/08 at 01:56 PM Reply With Quote
Surely that's not true? With a swing axle you have zero camber with the axle horizontal, negative camber on bump and positve camber on droop.
With Mac strut you have maximum negative camber with the lower arm horizontal and the camber heads towards zero/positive with movement in either direction from horizontal.
Jesus-Ninja
posted on 4/1/08 at 02:12 PM Reply With Quote
I would agree with you there. As in my original post, if the arm is horizontal, then the hub is at it's outer most point, as the arm swings in either direct, the hub moves inward. This motion inwrd causes the angle of the strut to reduce (on the assumption that it is angled into the body at the top), and so neg camber is reduced.
Hence my point about not having a horizontal arm at rest, but angled down at the outside, such that camber is increased, relative to the car, when the shck is compresseed
SkinnyG
posted on 4/1/08 at 04:29 PM Reply With Quote
Now add to the mix the fact that struts need fairly high steering axis inclination to get the strut out of the wheel (since everything cannot be packaged ~inside~ the wheel).
This also causes a loss of negative camber when the outside wheel is turned. This can be countered to a certain extent by increasing caster, but increasing caster has its own drawbacks.
Struts are cheap - they are not good. They can often be made to work, by optimizing the (wretched) camber curve as you describe, and by running high enough springs and bars to stop the struts from moving - thus stopping them from doing anything bad.
G
The Lethal Locost
