Author: Subject: Aprilia 2 stroke motorbike help?
sprouts-car
posted on 13/1/08 at 07:12 PM Reply With Quote
I have an aprilia rs50 which runs fine, until I just let it tick over. When ticking over it appears too much oil gets on the spark plug and stops it sparking in the right place.
Its an NGK spark plug, and i'm getting the problem of the spark being down inside the plug, not on the tip. Isn't it a stupid design to allow it to spark inside, or is there a reason for it?
Any thoughts?
ReMan
posted on 13/1/08 at 07:19 PM Reply With Quote
The plug is knackered/dirty.
Welcome to two -strokes
Check the oil mix if it's a pre mix, else the regulating system if it's a seperate tank.
Don't sit with it ticking over unnessesarilyy, give it some thrash
posted on 13/1/08 at 07:34 PM Reply With Quote
2 stroke oil pump not adjusted correctly??
afj
posted on 13/1/08 at 07:45 PM Reply With Quote
and use top quality oil
sprouts-car
posted on 13/1/08 at 08:04 PM Reply With Quote
Cheers guys, will check those things over. Thanks
