jobsagooden
| posted on 15/1/08 at 10:49 AM |
Tin Top HELP!!!
I all
Got pulled by the police the other day for having a headlight out which in itself is fine they did however give me a pink ticket which means
I've got 14 days to get it fixed take it too an MOT station and send the ticket back. Also this is fair enough at least I wasn't fined.
Anyway the problem is I've replaced the bulb and it's still not working all the other lights (main beam fog and sidelights) in the
assembly are working. It's a Y reg Fiat Marea estate and it may aswell be a Ferrari as far as parts prices are concerned and new headlight unit
is £204 + VAT is there anything else I can check for before I go replacing the whole unit.
All help is much appreciated.
PJ
RickRick
| posted on 15/1/08 at 10:54 AM |
check for the 12v supply to that bulb using a multi meter
ash_hammond
| posted on 15/1/08 at 10:56 AM |
Scrap yard - dont pay the price at the stealers.
.: www.mac1motorsports.co.uk | www.m1moc.com :.
Paul TigerB6
is that bulb on a seperate fuse??
| posted on 15/1/08 at 11:32 AM |
Suspect it is not earthing to the body or the connector.
Italian electrics !!!!
[Edited on 15/1/08 by britishtrident]
RazMan
| posted on 15/1/08 at 11:38 AM |
The Italians were never briliant at electrics were they
If everything else is working I would rule out an earth problem (which is very common) and I doubt that replacing the headlamp unit would achieve
anything.
First check if power is getting to the appropriate wire in the connector - if not then work backwards to the fuse box. Sounds simple doesn't it
Raz
TGR-ECOSSE
| posted on 15/1/08 at 11:55 AM |
I had the same problem and to get it through an M.O.T i took a feed from the other headlight as a temporary measure. Its probably still there
jobsagooden
| posted on 15/1/08 at 12:02 PM |
Cheers guys
it is on a seperate fuse but the fuse is fine.
Found two cars at scrap yards but they've both got front end damage so no joy there so off to borrow a multimeter
PJ
| posted on 15/1/08 at 03:17 PM |
Unlike Joesph Lucas ofcourse
RazMan
| posted on 15/1/08 at 05:04 PM |
Raz
