welshboy
posted on 18/1/08 at 08:20 PM |
steering joint
could any one tell me what other steering joint will fit on a mark 1-2 escort steering rack please the ecsort 1 i have seem very close to fu tube
TGR-ECOSSE
posted on 19/1/08 at 02:24 AM |
How close is it to the fu tube? I thought mine was close till i looked at some other cars and they were the same.
Ronnie
t.j.
posted on 19/1/08 at 08:29 AM |
I use the Cortina MK5(=Taunus Mk3) joint on the rack as the sierra one didn't fit. Then the rest is from the Sierra.
The ball-joint left and right are the sierra ones (M14). Maybe someone know if they are the same as the cortina/escort ones.
[Edited on 19/1/08 by t.j.]
Mark Allanson
posted on 19/1/08 at 11:49 AM |
Manual steer sierra will fit, but power steer will not.
welshboy
posted on 19/1/08 at 05:56 PM |
thats great info i will try a sierra one then i had tryed the power steering one and it would not fit so i will go for the non power steering thanks
everyone
Mark Allanson
posted on 19/1/08 at 06:23 PM |
The down side is that the non power sierra one has a cast section and the power has MS tube which is ideal for welding. I drilled out the rivets and
replaced with 8.8 M6 bolts so I unded up with the power down shaft and the non power clamp on the steering rack.
t.j.
posted on 19/1/08 at 07:00 PM |
hmmm, strange my 1989 sierra shaft didn't fit on the steering rack of the Mk2 escort. And the sierra didn't have power steer.
Are there different types then?
