Author: Subject: Tin Top Wiper problem
Slater
posted on 4/2/08 at 12:36 PM Reply With Quote
Help. The windscreen wipers on my VW Passat (1999) have started coming on at random, the only way to turn them off is to remove the fuse.
Any ideas what the problem could be? and how to fix?
It started happening after a day of snow last week, if that's any help?
Mr Whippy
posted on 4/2/08 at 12:46 PM Reply With Quote
Sounds like something has shifted position inside the wiper motor switch gear, perhaps due to ice jamming the wipers? I'd open it up and check nothings come loose
Their quite simple inside.
posted on 4/2/08 at 12:49 PM Reply With Quote
Insulation worn on the wiring, with intermittent contact? Perhaps where it goes through a hole in the chassis/bodywork?
Just a thought...
Agriv8
posted on 4/2/08 at 12:58 PM Reply With Quote
Had this on my 97 passat.
Assume this is the front wippers.
After buying the expensive control relay ( that did no fix it ) I have this if you need to test yours
The issue with mine was corrosion on the wire that connect the dash loom to the car loom. Have a look behind the pannel by your right ankle while you are driving.
regards
Agriv8
Slater
posted on 4/2/08 at 01:28 PM Reply With Quote
Thanks for the info, I'll have a look at the wiring and switchgear tonight.
Dusty
posted on 4/2/08 at 01:50 PM Reply With Quote
This is very irresponsible advice. I strongly recommend that you pull up, apply the handbrake and switch of the engine first
Agriv8
posted on 4/2/08 at 07:24 PM Reply With Quote
Oh check that the area where the battery is is ( and wipper motor ) is not full of water ( or sploshing about ) the drain holes do become blocked with leaves.
regards
agriv8
Agriv8
regards
agriv8
