James
posted on 8/2/08 at 10:50 AM |
Help! DIY disaster!
My Mum's got some posh distant relatives coming over and although generally embarassed about the state of the house she was particularly worried
about the flaking varnished mahogany front door.
She couldn't strip it down so I said I'd do it for her.
Spent all yesterday morning sanding it and rubbing it down. Couldn't get the sander in the tight corners etc. so I used Nitromors.
What I've then found to my horror was that this supposedly expensive door had PERSPEX and not glass panels. Consequently the Nitromors has melted
the Perspex and it looks bloomin awful!
I don't know what to do now as it looks like the wood is constructed around the perspex so I'll have to dismantle half the door to get it
apart to replace the 'glass'.
Looking to the ever-resourceful LB for help.
My nightmare:
Whole door
In detail:
Knackered 'glass'
The wood appears to be constructed on top of the glass:
'Glass' set behind wood?
Help other than "buy a new door" most appreciated!
Thanks,
James
[Edited on 8/2/08 by James]
EDIT: work was done on the outside of the door. Too cold and depressed to take from there though!
- Muhammad Ali
tegwin
posted on 8/2/08 at 10:53 AM |
Do the rest of the window with nitromorse....Itl look like frosted privacy glass....
Or how about cutting the plastic out and then fitting glass pannels with very small nails followed by window putty....(The old fashioned way)
RazMan
posted on 8/2/08 at 10:54 AM |
Make it a feature like TVR did with the huge door gaps?
Raz
posted on 8/2/08 at 10:56 AM |
take a photo of the inside looking through the door and smae of the outside then stick on the panels so they still appear to be glass.
rayward
posted on 8/2/08 at 10:57 AM |
b&q sell some stick on vinyl that makes glass look like etched glass(for privacy etc) it will cover up the bad bits
Ray
pewe
posted on 8/2/08 at 11:02 AM |
Cut some 6 mm ply to shape and stick it front and back on each "glass" panel then stain the same as the rest or the door. Given
there's a window next to the door you won't lose a significant amount of light. Also like rayward's suggestion of the stick-on
obscured viynl from B&Q as an alternative.
Cheers, Pewe
Fozzie
posted on 8/2/08 at 11:04 AM |
When are the rellies due over James?
Now the damage is done..I suppose it's useless to say never take owt for granted as to what the 'materials' are supposed to be!
and that preparation (masking etc) is very, very important..
Does Mum need the 'glass' to be kept clear?
Fozzie
just seen raywards post...seems like more of an easy fix than the one I was thinking of!
James
posted on 8/2/08 at 11:12 AM |
My Dad's always banging on about what an expensive quality door this was blah blah blah. Consequently never dawned on me it'd be anything
but glass.... not tacky placky plastic!
Although they 'wobble' I'm buggered if I can remove the central 'spokes' on top of the plastic. To try and remove it
properly.
So it seems vinyl is beginning to look like the most practical option.
Will pop to B&Q now and try a bit, see what it looks like.
James
- Muhammad Ali
iank
posted on 8/2/08 at 11:14 AM |
B&Q have a sale on at the moment
Can get an exterior door for less than £55 right now which might not be much more than repairing the current one.
linky
Anonymous
James
posted on 8/2/08 at 11:21 AM |
Foz,
Next weekend IIRC
iank,
A new door has been considered!!!
Problem with that is that (according to Dad) the frame is so out of true that it took a carpenter 2 days to hang the current one.
- Muhammad Ali
James
posted on 8/2/08 at 11:24 AM |
I like the idea of cutting out the plastic and fitting separate glass panels.... not sure about the nails and putty though... sounds a bit
difficult!
Can you buy curved beading/trim? Could fit that around where the glass has to go so it's secure.
At the end of the day, putty and nails would be easy to punch out the glass then reach in and open the door for burglars!
Gah!!!
Off to B&Q
- Muhammad Ali
tegwin
posted on 8/2/08 at 11:26 AM |
That presumably is why they have fitted plastic...
No reason why you cant get polycarbonate or perspex pannels cut out, stick them in with the putty and nails..
You only need a few nails either side of the glass/plastic to stop it moving whilst you put the putty on and let it set.
James
posted on 8/2/08 at 11:29 AM |
I think it's one single perspex panel with the wood fixed over the top and all around.... nice and secure!
- Muhammad Ali
Mr Whippy
posted on 8/2/08 at 11:35 AM |
there only one real option
get a new door, as the place will stink as the vanish drys even if you do repace the plastic. Have a look in classifieds as people are always selling
stuf like that.
chunkytfg
posted on 8/2/08 at 11:44 AM |
quote: Originally posted by James
Foz,
Next weekend IIRC
iank,
This the same dad that said it was a quality door?!!
Any chippy who's any good would have had that door hung in hours regardless of how out of true the frame is
billynomates
posted on 8/2/08 at 11:55 AM |
New door. There's no way you can repair that one and make it look any better than it does now. Not unless you get some proffessional help.
I'm not questioning your diy skills. But trying to fit bead and glass, or trying to fit glass with putty will never be as easy as it sounds.
billynomates
posted on 8/2/08 at 11:58 AM |
Don't know what the going rate for getting a door hung is in Surrey, but it's no more than half a days work, get somebody to agree a price
on the phone and let them worry about the twisted frame when they get there.
Dangle_kt
posted on 8/2/08 at 12:20 PM |
Frosted glass look would be fine I reakon. You dont need a new door for THAT!
JonBowden
posted on 8/2/08 at 12:34 PM |
if you are good at woodwork, you could :
Remove the perspex and the radial sections leaving a half circle hole
have a new piece of glass made up to fit
Support the glass on one side with trim pinned and glued to the door
hold the glass in place with brown silicone sealant
Jon
Humbug
posted on 8/2/08 at 12:42 PM |
use a piece of fine sandpaper and go over the perspex for a DIY frosted look. Should be OK... can't be any worse
Jasper
posted on 8/2/08 at 12:53 PM |
Stop with the bloody DIY and get that car finished
tegwin
posted on 8/2/08 at 12:54 PM |
Torch the house...claim on insurance...
Get new door for free
DaveFJ
posted on 8/2/08 at 01:05 PM |
try a polishing wheel on a dremel... it will be distorted a bit but you should be able to get it clear again...
If its really bad the use some >1500 grit wet and dry first.
Dave
McLannahan
posted on 8/2/08 at 01:16 PM |
You can buy glass frosting spray (Sounds like Tartan paint but I assure you it does exist!)
Two seconds to spray over that and none of the hassle of that fiddly sticky plastic sheet!
Linky here!
[Edited on 8/2/08 by McLannahan]
alfasudsprint
posted on 8/2/08 at 01:46 PM |
You could fairly easily hang the door yourself mate, measure it up see if its a standard size. You can easily cut a door down for height, width a
planer is required really. Twisted frame may make fitting lock difficult.
On another note, are there beads on the outside (they should be on the inside for security and weathering). If no beads, no way you will get that
out.
BTW if you want to tart the place up, buy a letter plate tidy for inside. Or dont bother and they'll be gone and forgotten in a couple of
days!
Good luck.
