RazMan
| posted on 8/2/08 at 01:15 PM |
Rear Projection TV Repair?
I've got a Sony KP-41S5U Rear Projection TV which has suddenly developed a fault. The top left of the image has a blue 'droop'
almost as though the image is peeling away from the screen. I assume that this means the blue 'gun' is FUBAR and needs to be replaced -
trouble is where do I get one? Is it worth repairing or should I just chuck it in the nearest (large) skip and replace it with a 52" LCD ?
I have searched through quite a few TV geek forums with no success so I thought I would turn to you guys
Raz
Mr Whippy
| posted on 8/2/08 at 01:24 PM |
are you sure about the gun? I thought rear projection involved a spinning wheel and LCD screens. Why not open it up first to see if anything obvious
is wrong.
RazMan
| posted on 8/2/08 at 01:29 PM |
I had a similar problem on an earlier model of this TV. I ended up giving it to a local repair guy who replaced the 'gun' but
unfortunately the convergance was so bad it was unuseable - looked like my vision after a night on the lash
The reason was (would you believe) they used a wooden chassis which warped so badly once it was disturbed that you could never align the guns again.
I'm not sure but I think this model has an alloy chassis which might mean that it is repairable.
Hmmm ... now where's my toolkit ....
Raz
Mr Whippy
| posted on 8/2/08 at 01:37 PM |
nope I'm not impressed with that design
RazMan
| posted on 8/2/08 at 02:16 PM |
Yep, that confirms it - three whacking great lenses with hi-res image projectors of some sort. Looking at the surface of the blue one, I can see
distortion on the edge of the image.
Now I need to see if the part is available anywhere. I'll give my local Sony agent a call ...
*edit* ..... who tells me that it is likely to be a couple of convergance ICs costing about £180 to replace
Hmmmmm dilemma time, do I tell swmbo that it is unrepairable and order the 52" LCD instead ?
[Edited on 8-2-08 by RazMan]
Raz
graememk
| posted on 8/2/08 at 03:25 PM |
have a decorating accident and call your house insurance
Mr Whippy
| posted on 8/2/08 at 04:07 PM |
to do that you have to prove it cannot be economically repaired therefore it must ‘accidentally’ end up in a million pieces…
do you have an upstairs window?
RazMan
| posted on 8/2/08 at 05:10 PM |
How does ANYONE accidentally drop a 42" TV out of an upstairs window - assuming you can find one big enough.
I might have to stage a horrific accident which involves a large lorry, carreering off the main road (half a mile away) and crashing through the
lounge wall, crushing said TV ............. but I think I see a flaw in that plan
Raz
chunkytfg
| posted on 8/2/08 at 06:15 PM |
Or maybe a wall?!!
dan__wright
| posted on 8/2/08 at 08:03 PM |
shelf above it with a rather heavy metal or stone ornament coming off the wall and smashing through?
FREE THE ROADSTER ONE…!!
RazMan
| posted on 8/2/08 at 08:51 PM |
LOL I knew that I would eventually find a use for that comedy anvil (with Acme Anvils stamped on the side)
Or maybe I can just plead insanity and say that I thought ALL Tvs were wall mounted nowadays (it weighs a ton) and say that it brought the wall down
with it.
Now where's that insurance company's number? .....
Now, on to the serious business - where can I find a good deal on a 40+" LCD TV? Comets and Currys just have a standard rrp pricelist but who
imports and sells direct to Joe Public?
Raz
RazMan
| posted on 10/2/08 at 12:00 AM |
*Update*
50" Panasonic Plasma now installed - now looking for a large skip or someone to take the old TV off my hands.
Size really IS important after all
Raz
