speedyxjs
| posted on 12/2/08 at 07:40 PM |
Paddle shift for auto box?
I was wondering, can you get a paddle shift for an automatic gearbox?
blakep82
| posted on 12/2/08 at 07:42 PM |
erm, why would you need one on an auto?
seen a bus (i know! i actually got a bus! :O) a few weeks back, and instead of a lever for drive neutral or reverse, it just 3 buttons. reckon that
would be cool
________________________
| posted on 12/2/08 at 07:43 PM |
By definition, I would say not. However, you can with semi-automatic.....
Phil
speedyxjs
More control, sportier feel, look cool etc
Volvorsport
| posted on 12/2/08 at 08:06 PM |
http://forums.turbobricks.com/showthread.php?t=47229
www.dbsmotorsport.co.uk
getting dirty under a bus
speedyxjs
| posted on 12/2/08 at 08:42 PM |
Wow, cool thread but would that work on an electronic box?
mark chandler
| posted on 12/2/08 at 10:19 PM |
I do not think you have an electonic box, merely a box with sport mode which holds the gears and tightens the shift. Jags of your donor era were
fitted with a ZF-HP-22 box.
If you have a look around and get an earlier Borgwarner type66 SI - Early SIII xj jags you can remove the auto function so end up with essentially 1st
second and third selectable, the later GM400 can also be fiddled with but its huge and heavy so the BW is best for locost weight reasons.
Regards Mark
Volvorsport
| posted on 12/2/08 at 10:36 PM |
if it has solenoids/relays that you can control to change gear then yes you can - best get the manuals out .
speedyxjs
| posted on 13/2/08 at 07:30 AM |
I have the 'J' gate in mine so i can select 2nd to 4th but thought it would be cooler with paddle shift
Im not very electronicly minded at the mo but maybe when i am (after building my own sports car ) i will be able to work out relays and stuff.
[Edited on 13-2-08 by speedyxjs]
Paul TigerB6
| posted on 13/2/08 at 08:45 AM |
ermmmmm - that sounds like you are describing a manual box to me!!
| posted on 13/2/08 at 09:50 AM |
(I'm surprised Hellfire hasn't pointed this out)
Stick a bike engine/box in it
speedyxjs
| posted on 13/2/08 at 01:23 PM |
Dont think a bike engine will do much for a 2 ton jag
