Author: Subject: OT. Washing machine
Dingz
posted on 25/2/08 at 10:45 PM Reply With Quote
OT. Washing machine
Anyone know how difficult it is to change the bearings on a Hotpoint Aquarius WD440, and how it comes apart?
onzarob
posted on 25/2/08 at 10:50 PM Reply With Quote
I haven't change bearing in that model, but its fairly straight forward.
you will need to take the back off, from there it simple and will be self explanatory
westf27
posted on 25/2/08 at 11:05 PM Reply With Quote
complete front off,tub assy.out and split into two halves.drum out check shaft and change bearings
Mr Whippy
posted on 25/2/08 at 11:17 PM Reply With Quote
eh?
just take the back cover off and you'll see the pully. Take the belt off and then remove the bearing holder casting (usually bolted onto the frame), then press out the bearing. Very straight forward so long as you have a vice.
here's a link there all boringly similar -
http://www.eveshamsquash.co.uk/appliances/aeg_bearing.html
a quote from it - 'I've had the AEG 6350 for nine years. For the first seven years, we were doing between 15 and 20 washes a week (babies' terry nappies and lots of squash kit). That's 6,000 washes!' - remind me never to have kids...
[Edited on 25/2/08 by Mr Whippy]
westf27
posted on 26/2/08 at 08:25 AM Reply With Quote
Whippy its what I do for the day job.They have moved on.Very few if any are like your old AEG and most likely your next AEG will have moved to this type of build
Mr Whippy
posted on 26/2/08 at 08:38 AM Reply With Quote
oh great they used to be a doddle, typical
Dingz
posted on 26/2/08 at 08:39 AM Reply With Quote
Many thanks chaps, it is my daughters, and about 15 miles away, thats what she thinks has happened to it but it is only about 2 months out of warranty. The last one I took right to pieces had to come out of the top.
pif
posted on 26/2/08 at 09:46 AM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=62863
try this ink if it applies to your machine
pif
been a bit of a rush job really, bodged it all together in just 5 1/2 years.
