Author: Subject: Removing a doink
RazMan
posted on 26/2/08 at 01:05 PM Reply With Quote
Removing a doink
My runabout Escort has got its fair share of battle scars for a 12 year old car but there is a 2" dia 'doink' on the bonnet which looks like it will pop out easily ... if I could get behind it with a rubber hammer.
Is there an easy way to pull it out from the front? Some sort of vacuum plunger thingy or do I have to resort to filler?
Raz
dan__wright
posted on 26/2/08 at 01:08 PM Reply With Quote
ive seen a vid of it and it work surprisingly well, heat it with a hair dryer or heat gun (obv be careful with the heat gun not to take the paint off)
get a bottle of c02 (the used an air duster) hold it upside down so that if you spray it you get liquid c02 and spray it on the hot dent, caused it to pop straight out.
FREE THE ROADSTER ONE…!!
dan__wright
posted on 26/2/08 at 01:11 PM Reply With Quote
vid here :
http://www.metacafe.com/watch/501379/remove_car_dent_with_airduster/
worX
posted on 26/2/08 at 01:12 PM Reply With Quote
Slide hammer and glue on disc...
Mr Whippy
posted on 26/2/08 at 01:13 PM Reply With Quote
Drop the bonnet on your head, if your well positioned it should just pop out
carpmart
posted on 26/2/08 at 02:02 PM Reply With Quote
Originally posted by dan__wright
vid here :
Thats pretty clever stuff! Might give that a go on the wifes Cooper S as its got a small dent. Is this technique particular to size of dent? Will a small one pop just as easily?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
posted on 26/2/08 at 02:05 PM Reply With Quote
leave that doink alone - you'll only fix it and add another one soon after (murphy's law). If the car's 12 years old, concentrate on the mechanicals and nurse it gently.
milson
posted on 26/2/08 at 02:28 PM Reply With Quote
RazMan
posted on 26/2/08 at 06:52 PM Reply With Quote
Thanks guys (yes, even Mr.W)
That vid is superb - I will definitely give it a go when I can find some CO2 to squirt at it. [sideways glance to fire extinguisher]
Raz
posted on 26/2/08 at 07:12 PM Reply With Quote
IIRC Sealey sell a dent puller like a big sucker with a handle for just that sort of job
RazMan
posted on 26/2/08 at 07:25 PM Reply With Quote
Just a thought - does deoderant use CO2 as a propellant? It would smell nice too
Raz
mark chandler
posted on 26/2/08 at 08:16 PM Reply With Quote
Suction cup from B&Q used for picking up glass etc.
posted on 26/2/08 at 09:41 PM Reply With Quote
No, they use Butane or Propane!
matt.c
posted on 27/2/08 at 09:32 PM Reply With Quote
Just use a dolly and a flipper.......
RazMan
posted on 12/3/08 at 07:43 PM Reply With Quote
Update: I finally got round to trying the 'heat & freeze' method as suggested. I heated the area with a hairdyer foe a minute or so, then sprayed on the liquid CO2 from an air duster ........... absolutely nothing happened It might be due to the fact that this is a very small doink and was caused by a fair sized stone thrown up by a lorry (good job it didn't hit the screen) so the metal has had a fair old whack which probably needs to be yanked out by more brutal means ................. I think I'll live with it now
Raz
