Author: Subject: Rover crankshaft sensor
darrens
posted on 27/2/08 at 07:14 PM Reply With Quote
Anyone know a stockist of above, specifically for 75 (not mine might I add)
cheers
zzr1100rick2
posted on 27/2/08 at 07:27 PM Reply With Quote
I would think Rimmer Bros in lincoln would have one www.rimmerbros.co.uk
stevec
posted on 27/2/08 at 07:59 PM Reply With Quote
Is it the inductive type or the Hall effect type?
I have some new K series inductive ones.
Steve.
darrens
posted on 27/2/08 at 08:04 PM Reply With Quote
not sure actually, I know it's the round flat one, not the one that has the little nobbily bit sticking out of it. 3 Pins if I remember.
cheers
[Edited on 27/2/08 by darrens]
stevec
posted on 27/2/08 at 08:07 PM Reply With Quote
That is the Hall effect type then. Allen Ford in Coventry are Rover parts suppliers, not sure if they do Mail order.
Steve.
posted on 27/2/08 at 09:23 PM Reply With Quote
The 75 sensor is different from the other Rover saloons, the 75 uses a variation on BMW part (may be same part as equivalent Freelander) exact type also will depend on engine and year the V6 has a different make of ECU from the in line 4 --- also 75 sensors were upgraded quite early in the production life of the 75 due to a reliability issue with the connector. I would recommend using Rimmer Bros very good on delivery.
darrens
posted on 27/2/08 at 11:05 PM Reply With Quote
cheers for info guys
