Author: Subject: the dent thing question
Mr Whippy
posted on 29/2/08 at 10:32 AM Reply With Quote
remember the clip where CO2 was used to pop out a dent, does anyone know if the CO2 should be sprayed in the dip of the dent or does it matter. Reason I ask is I have a dent on a door which is really a bulge rather than a dent due to being hit from the inside of the car. You might need to read that twice thanks to how bad I just wrote that anyway I've got a can of gas and want to try it out over the weekend. Anyone know the answer?
dan__wright
posted on 29/2/08 at 10:38 AM Reply With Quote
i guess do it from the inside.
FREE THE ROADSTER ONE…!!
posted on 29/2/08 at 10:39 AM Reply With Quote
hit it with a hammer to push it in.
Mr Whippy
posted on 29/2/08 at 10:43 AM Reply With Quote
well I'm trying to avoid the hammer as the clip showed the panel simply poping back into shape. I should have mensioned that the dent is behind a inner skin and hence it's not been fixed. I was going to drill a little hole for the nozzel to spray through and heat the panel from the outside with the hairdryer.
Richard Quinn
posted on 29/2/08 at 10:47 AM Reply With Quote
Park it next to my Missus' car. She'd knock it back in with her door in no time!!
RazMan
posted on 29/2/08 at 10:53 AM Reply With Quote
The clip showed the CO2 being sprayed all over the dent. I imagine the force is generated by the skin cooling faster than the rest of the metal, therefore generating a powerful contraction effect.
I'm certainly going to give this a go when I get a day off.
Raz
posted on 29/2/08 at 11:11 AM Reply With Quote
^^^^ interesting. I would have thought it would be difference in air temperature resulting in pressure difference that was the driving force.
anyone know how it works?
Mr Whippy
posted on 29/2/08 at 11:55 AM Reply With Quote
I'd say that sounds a good theory, so might not matter which side it is.
[Edited on 29/2/08 by Mr Whippy]
