pjavon
| posted on 2/3/08 at 12:19 PM |
Wheel PCD
Can anyone help me, is the pcd on a peugeot the same as ford i.e. 108
Thanks Paul
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
Paul TigerB6
| posted on 2/3/08 at 12:23 PM |
yes
http://www.carlsalter.com/wheel_fitments.html
pjavon
| posted on 2/3/08 at 01:28 PM |
Thanks, i'll go and buy my new wheels now
Paul
zilspeed
| posted on 2/3/08 at 03:28 PM |
Remember that the nuts can be different.
Peugeots as standard have a curved seat and Ford have a tapered seat, so double check yer nuts before use !!
In other words, make sure that the nuts and the wheels match.
mcerd1
| posted on 2/3/08 at 03:52 PM |
also
the pugs use a slightly bigger centre bore (couple of mm's)
if they are after market wheels with the plastic rings in the centre - you should be able to get a ford sized set to replace them (63.4mm)
