SierraL_killer
| posted on 4/3/08 at 07:33 PM |
Turbo Hunting - 1.9Tdi - Tin top prob
The car I have at the mo has a strange problem where the turbo keeps speeding up and slowing down during acceleration. This usually occurs when
accelerating in 4th and 5th gears.
It kicks in normally at 2krpm, drops out again at about 2.5-3krpm and then does this horrible speed up, slow down, speed up, slow down until you
change gear. This makes the car drive in lunges rather than just accelerating steadily.
The turbo doesnt smoke and it makes all the normal whining noises.
Any remedies as I feel like I'm riding to work on a kangaroo!?
Cheers for any help!
cossiebri
| posted on 4/3/08 at 07:35 PM |
could it be the actuator?? sounds like it is bleeding off the boost
If it doesn't fit MODIFY it!!
Cheers BriF
ASH3
| posted on 4/3/08 at 07:38 PM |
Sounds like air flow meter to me thats
what cured my tdi with the same symptoms. Factors do them now so dont
go to main dealer
itiejim
The MAF (air flow) meter is another common culprit. Try unplugging it and se what happens then, if it runs much better (perhaps a bit rich) then it
needs replacing.
itiejim
| posted on 4/3/08 at 07:39 PM |
Oops - too late...
Danozeman
| posted on 4/3/08 at 08:06 PM |
What car is it? VAG TDi??
Sounds like airflow meter or vacuum pipes from turbo to ecu if it is.. The airflow meter on VAG tdi's are common. Dont get a genuine one.
they cost a fotrune!
Dan
onzarob
| posted on 4/3/08 at 09:10 PM |
quote: Originally posted by Danozeman
Dont get a genuine one. they cost a fotrune!
last quote I got was £56 from VW and £40 for an oem one.VW prices have drop lately My Cambelt kit was less from VW than from the local parts place
| posted on 4/3/08 at 09:46 PM |
Waste gate flutter? Is the waste gate tight and sealing correctly?
onzarob
| posted on 4/3/08 at 10:04 PM |
Which Tin top is it as later VW TDis are recirculating turbo's, the earlier one are waste-gate versions.
SierraL_killer
| posted on 4/3/08 at 10:46 PM |
Cheers for the quick responses guys - I'll check sensors and bits out tommorrow.
Its a Seat Toledo (VW engine) from '97.
Thanks again!
