Pdlewis
| posted on 4/3/08 at 08:19 PM |
OT: JTD
Just somthing which is playing on the back of my mind I recently had my Alfa 147 JTD service and since the service it seems to be throwing out alot
more black smoke under acceleration (like a chipped vag) and i was expecting the mpg to go up as it usually does after a service to arround 44mpg (as
it usually does) but its sticked at the 40 mpg i was getting just before the service.
I was thinking there may be an oil leak in the turbo but the oil doesnt seem to be going down
any suggestions of what to check are welcome
Paul
onzarob
| posted on 4/3/08 at 08:23 PM |
Black smoke is over fuelling, blue would be an oil leak. I would say that the pump timing may be slightly out
Hugh_
| posted on 4/3/08 at 08:39 PM |
Everytime I've had my toledo serviced the oil has been overfilled. As a result for the first 2000miles ish I get slightly worst fuel
consumptions (~2-3mpg reduction) and it belches smoke on hard acceleration.
Pdlewis
| posted on 4/3/08 at 08:44 PM |
That sounds a bit more comferting as it only started throwing out smoke after the service
delboy
| posted on 4/3/08 at 08:57 PM |
Have a really good look at the hose from the turbo, I've seen a few with a little split in them which then causes black smoke, it doesn't
take much.
