Author: Subject: How is this MILL part called
tks
posted on 6/3/08 at 01:46 PM Reply With Quote
whats the name of this holder and their inserts....
Regards,
Tks
[Edited on 6/3/08 by tks]
Mr Whippy
posted on 6/3/08 at 01:48 PM Reply With Quote
milling chuck & collets?
http://www.collistool.com/endmilh2.htm
[Edited on 6/3/08 by Mr Whippy]
badding
posted on 6/3/08 at 03:09 PM Reply With Quote
I only know the dutch words...
Freesdoorn =milling-cutter arbor
en spantang = don't know
thomas4age
posted on 6/3/08 at 05:47 PM Reply With Quote
Spantang = collet
picture looks like an (dutch): Iso opname voor de frees.
call HBM or De Locloods they'll know what you need
Grtz Thomas
(succes met de CNC trouwens klinkt goed!)
[Edited on 6/3/08 by thomas4age]
If Lucas made guns, Wars wouldn't start either.
neilj37
posted on 6/3/08 at 06:57 PM Reply With Quote
i would call it a collet
SPYDER
posted on 6/3/08 at 07:43 PM Reply With Quote
The main body is called an ARBOR.
The COLLET is the segmented inner piece that actually grips the tool when the nut on the end is tightened. The collets come in various syles and sizes and are quickly and easily changed to suit whatever tool is to be used.
On some machines the coolant passes through the arbor and collet and fires directly onto the tool.
Trust me, I use these all day, every day.
Geoff.
Alan B
posted on 12/3/08 at 06:39 PM Reply With Quote
The main body is a toolholder, probably a SK, BT or CAT 30 or 40 size for what look like Erickson or similar collets.
http://www.commandtool.com/products_services/cnctoolholding.cfm
