Author: Subject: OT Baxi Combi 105e Problem
stevec
posted on 9/3/08 at 01:36 PM Reply With Quote
I have a Baxi 105e combi boiler.
I am suspecting the usual pcb problem.
I have heating but the hot water fails intermittently, when it does the fan led flashes.
This fault is linked to a flue related fault but as I say the heating works fine.
I have checked the water inlet filter and the water flow is very good.
Has anyone had any experience with a fault like this.
Cheers.
Steve.
eccsmk
posted on 9/3/08 at 03:34 PM Reply With Quote
http://www.askthequestion.co.uk/phpBB2/about3200.html&highlight=baxi+combi+105e+problem
hope thats of help just had a quick search using google
[Edited on 9/3/08 by eccsmk]
stevec
posted on 9/3/08 at 03:55 PM Reply With Quote
Thanks for that.
Steve.
RickRick
posted on 9/3/08 at 04:51 PM Reply With Quote
i've just had a very sililar problem fixed on my baxi my problem was a switch with 2 pipes running into it, possably pressure differental switch needed that replacing.
stevec
posted on 9/3/08 at 05:30 PM Reply With Quote
Looking at the flow chart in the book it is pointing in that direction,
Was it the micro switch attached to it that was replaced or the whole pressure unit?
Cheers.
DarrenW
posted on 10/3/08 at 09:53 AM Reply With Quote
Ihad very similar fault. It was the diaphragm seal in the diverter valve. Small hole in it.
In summary when your heating is on the system is heated and pumped round etc, when you want hot water the diverter valve switches from central heating to hot water. If the diaphragm is starting to fail then sometimes you get hot water and sometimes you dont. It an come out hot for a while then go cold on you (basically its going back to central heating mode).
Tok me ages to suss mine out as there wasnt a sequence for it. All i realised was that everytime the hot water went cold the central heating came back on.
Hope this helps you diagnose yours.
BTW the seals were approx £6 iirc - a rip off but cheaper than replacing full parts.
[Edited on 10/3/08 by DarrenW]
