Author: Subject: Women - "Fuel Guage...whats that for then?"
locoboy
posted on 4/11/03 at 01:08 PM Reply With Quote
Could be one for Ned!
My girlfriend has run out of Diesel (again) in her 306 HDi,
the car re-started and got her home (3 miles) after putting a 5 litre can in the tank.
It now sounds like a bag of shyte, i assume this will be air in the fuel still as it has not had time to bleed out.
Is it safe to drive to a petrol station brobably about 8 miles, what damage can be done if any?
I am led to beleive the system can self bleed.
Locoboy
MK9R
posted on 4/11/03 at 01:28 PM Reply With Quote
Be very careful with the peugeot diesel as the fuel pumps seize up if ran with no fuel in it. My dad had a 306 TD and got contaminated fuel in it which blocked the filter, he wrecked 2 fuel pumps which was very expensive!!!!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Mk-Ninja
posted on 4/11/03 at 01:30 PM Reply With Quote
I ran out of fuel in company 406 HDi, I put some fuel in, it splutted a bit, gave it a blast down the motorway and that was that, ran like a dream, dont know if I was lucky or what .
By the way this one had a faulty gauge, it was reading 1/4 full when it ran out.
Gordon
I'm sure I've got one, just don't know where I've put it
posted on 4/11/03 at 01:45 PM Reply With Quote
thats what they all say...!
ChrisW
posted on 4/11/03 at 05:02 PM Reply With Quote
You can circulate the fuel in the low pressure diesels by working the hand pump under the bonnet. I would imagine a few minutes hard pumping (oo-er!) would push all the air out? Or perhaps I'm misunderstanding how it works!!
Chris
My gaff my rules
posted on 4/11/03 at 10:07 PM Reply With Quote
...our lass did the same, but if I'd gone to pick her up in the tank, I would have asked her to sit and wait for a minute or two. Drove a safe distance away, then promptly directed the Howitzer at it... especially if it was the second time!!!
Don't waste your hard earned putting 5 Ltr's in next time - oh yes, there will be one, it's in the genes!
locoboy
posted on 5/11/03 at 09:21 AM Reply With Quote
There is no hand pump on the new HDi engines unfortunately, but i did decide to take it for a blast to see what happened, it seemed to correct its self within a few miles and seems ok now apart from maybe a kind of whistling/sucking noise but it may just be me being paranoid!Thanks for your advice/friendly wee take etc...
She has been warned that there will not be another time!
Locoboy
ned
posted on 5/11/03 at 10:29 AM Reply With Quote
i've run out of diesel on my 1.9td before, takes ages to pump the fuel back from the tank (to the point of nearly flattening the battery) unless you use the little primer squeezy thing under the bonnet.
don't know too much about the hdi engines (what does the 'HDI' bit stand for anyone?)
Ned.
beware, I've got yellow skin
posted on 5/11/03 at 12:19 PM Reply With Quote
You don't have to get all technical on us Bob. Keep it simple for the mechanically challenged amongst us. It helps if you disconnect the union at the injector as there is less pressure in the system and it pumps easier. Crack them open 1 to 4 and bleed till fuel gets there either with the lifter pump or battery then tighten them and start up.
yours, Pete.
locoboy
posted on 5/11/03 at 12:59 PM Reply With Quote
Ned,
I thnk its High pressure Direct Injection.
Locoboy
ned
posted on 5/11/03 at 03:53 PM Reply With Quote
thanks col.
peteff, i didn't see bobs post?
Ned.
theconrodkid
posted on 5/11/03 at 04:11 PM Reply With Quote
on the new common rail hp pump thingys
dont crack the pipes as they wont seal again,run at stupid pressure,electric pump in the tank as well
who cares who wins
pass the pork pies
locoboy
posted on 5/11/03 at 04:13 PM Reply With Quote
That may explain the god awful whining noise i heard while the pre heaters were working, it was probably some fuel pump that gets the system up to pressure before you start it, trying to pressurise air rather than fuel.
Locoboy
