graememk
| posted on 17/3/08 at 10:59 PM |
Oil radiator
do you know if and where you can get an oil filled radiator that looks like a normal rad ?
i want one to go in the utility but want it to look nice
MkIndy7
| posted on 17/3/08 at 11:13 PM |
You can get electric immersion heaters to turn a normal (CH type) towel rail into an electric one.
As they use the same valves this could also presumably be used on a radiator.. but i'm not sure if the output would be upto what a normal CH
type radiator would be.
Guinness
| posted on 18/3/08 at 07:22 AM |
Is it just to take the chill off / stop frost?
I fitted one of these underneath the units in my utility (my units are on legs, rather than a plinth).
120w version is £15 and took the average temp of my un-heated utility from 5C to 15C.
Linky to Screwfix
HTH
Mike
