Author: Subject: Large Fishtank, Will the floor take it ??
Andybarbet
posted on 21/3/08 at 01:27 PM Reply With Quote
Hi chaps,
I have a 5ft x 2ft fishtank which holds 400 litres of water, i think that equates to 400kg's of weight + the tank itself which maybe about 80kg's.
Question is, i live in a townhouse so i want it in the lounge which is one floor up, i have checked the floor joists and they run in the direction shown in my poor drawing below (if i can get the drawing on here !), the tank will sit on about four of them where they meet the wall between us and nextdoor, before i get round to filling it with water, are there any experts who think this is a bad idea and i might end up with it falling through the ceiling into the dining room below ??
Any recommendations gratefully received..........
worX
posted on 21/3/08 at 01:32 PM Reply With Quote
I am in no way an architect or builder etc, but I would be very surprised if that floor area wasn't designed and built to cope with 4 people (I'm 100 kilos).
Also "your" weight is a static weight, not dynamic like walking round or even someone having a party with dancing etc.
Like I say I'm no expert, but I'd be very surprised if you were risking it.
If you are worried you could get a larger base and therefore spread the load over more of your joists...
[Edited on 21/3/08 by worX]
Andybarbet
posted on 21/3/08 at 01:35 PM Reply With Quote
Cant seem to get my rough sketch on here, did it in paint program....
It will basically be sitting on the first 2ft of each joist where they are anchored into the wall.
TGR-ECOSSE
posted on 21/3/08 at 01:36 PM Reply With Quote
It should be ok if the stand spreads the weight evenly. I have seen 6'x2'x2' tanks and bigger in upper floors with no problems.
Danozeman
posted on 21/3/08 at 01:41 PM Reply With Quote
I would say itl be fine. Is it an old townhouse?
Dan
Andybarbet
posted on 21/3/08 at 01:55 PM Reply With Quote
House is probably late 60's early 70's i would think, its an ex council house
jlparsons
posted on 21/3/08 at 02:57 PM Reply With Quote
if it's sitting across several joists at their ends where they join the supporting wall you'd be fine. If it was going to be supported by just 1-2 joists in the middle of their beam I'd be concerned.
That said, I'm no expert and it ain't my house I'd be betting on!
If in doubt, have the boards up and stick a couple more joists in. It ain't difficult or particularly expensive.
[Edited on 21/3/08 by jlparsons]
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
dhutch
posted on 21/3/08 at 03:37 PM Reply With Quote
Your talking about half a ton. Sounds like quite a lot, but as steve says if you think about it as people its less alarmingly big.
I would agree it all depends on how its spread out really. If its on just four thin legs your proberbly as likly to punch thought the floorboards than anything else.
But said, assuming its spread out evenly, and the joists arnt knackered, and your not going to have 60 people in there raving, i'd say you will proberbly be fine!
Daniel
mangogrooveworkshop
posted on 21/3/08 at 08:09 PM Reply With Quote
shucx is that how much it weighs......had a tank the same a while back sat on joists ok
