Author: Subject: QUESTION ON VAUX XE FLYWHEEL
TOO BADD
posted on 22/3/08 at 03:22 PM Reply With Quote
Does any one know how light an xe flywheel can be taken to without going to a 71/4 " clutch.... ie keep standard one. Thought I might as well as the engine is out to change the rear crank seal.
ned
posted on 22/3/08 at 03:55 PM Reply With Quote
its not really how light, it's how weak it becomes. You don't want machined too thin cast flywheel disintegrating at several thousand rpm, makes a bit of a mess.
beware, I've got yellow skin
TOO BADD
posted on 22/3/08 at 04:10 PM Reply With Quote
There is a couple of new 'ultra lightweight' steel flywheels on the bay @ £ 125 plus post and I am condidering this route.
ned
posted on 22/3/08 at 04:18 PM Reply With Quote
I paid £95 odd for mine a few years back, takes a 7.25" clutch and weighs 3kg. Engine revs up very nicely with it on
Make sure you get it balanced up properly and along with whatever clutch you opt for.
Ned.
philw
posted on 22/3/08 at 04:56 PM Reply With Quote
If you get an early xe flywheel they are lighter than the later ones, by about 2-3kgs IIRC.
TOO BADD
posted on 22/3/08 at 06:20 PM Reply With Quote
Dunno if mine is an early but it is from a 91 engine. Just spent 2 hrs heavy duty web searching info. Found out that 1kg removed from a flywheel equates to losing 39kg's from the chassis in 1st gear...12kg's in 2nd and so on. So having a 2kg lighter flywheel is the same as losing me out of the car. Well...nearly!
philw
posted on 22/3/08 at 06:29 PM Reply With Quote
How heavy is the one you have? and whats the block number? it will begin with HH or HG
[Edited on 22/3/08 by philw]
TOO BADD
posted on 22/3/08 at 06:39 PM Reply With Quote
Just weighed it on the fat scales and it is about 6kg's. Autosprint had a little fettle with it when I first built the engine in 2002
philw
posted on 22/3/08 at 07:15 PM Reply With Quote
Thats about right 6kgs, the next step is a steel one as has been said before, i use a manta flywheel 5kgs but i have a different bottom end.
TOO BADD
posted on 22/3/08 at 07:42 PM Reply With Quote
The steel ones seem to be about 5.5 kg's which would still be an improvement on 6. £££'s for 1/2 kilo.....don't know.
ned
posted on 22/3/08 at 07:54 PM Reply With Quote
this is my setup, very light, and so was my wallet...
http://www.locostbuilders.co.uk/upload/IMG_1445.jpg
http://www.locostbuilders.co.uk/upload/IMG_1444.jpg
http://www.locostbuilders.co.uk/upload/IMG_1514a.jpg
a friend of mine had this one specially made smaller diameter to keep the centrifugal forces down aswell:
http://www.locostbuilders.co.uk/upload/IMG_1906b.jpg
Ned.
[Edited on 22/3/08 by ned]
philw
posted on 22/3/08 at 08:09 PM Reply With Quote
I thought the steel ones were 3kgs ish
posted on 22/3/08 at 10:14 PM Reply With Quote
Not quite that simple, it depends where the weight is removed from. The weight in the centre of a flywheel has negligible effect compared to the weight on the outside edge.
ned
posted on 24/3/08 at 01:15 PM Reply With Quote
Mine was advertised as just under 3kg's though I've never bothered to weigh it.
ned
posted on 24/3/08 at 01:17 PM Reply With Quote
Agreed, hence often skeletal or drilled round the outer section outside the fricton area where the mass makes the most difference and why for ultimate/race applications a smaller flywheel is preferred where regs allow to get the weight as near the centre as possible.
Less mass to spin up and down allowing the engine to rev free-er.
