eccsmk
| posted on 23/3/08 at 08:11 PM |
holding down felt?
since we had all the high winds my garage roof has lost all its felt is there any way of sticking it down (the new felt)?
it was just nailed down with broad felt nails with a few latts as extra support before
again thanks in advance
nitram38
| posted on 23/3/08 at 08:15 PM |
You can buy tar based adhesives.
Just paint on and stick it down. Use nails while it is curing.
Just make sure nothing is underneath if there are gaps/holes as it will run through!
Not nice on your car's paintwork!
The other way is to buy pitch and melt it in a pot (using a proper propane burner) and pour it on and spread it. Quickly put the felt over it before
it sets.
[Edited on 23/3/2008 by nitram38]
eccsmk
| posted on 23/3/08 at 08:25 PM |
ill have to try google wasn't happy as the snow stayed on my room but as it melted it soaked through all the gaps
on my bench grinder, beer fridge, radio
thank you
zilspeed
| posted on 23/3/08 at 08:27 PM |
Or, use torch on felt.
Cut to size and part melt the underside of the felt as you roll it on.
One of the roofers will be along soon for a full run down.
A treated timber strap at every second rafter position is also a good insurance policy. (That's the joiner in me coming out.)
Kev99
| posted on 23/3/08 at 08:36 PM |
Wickes easy seal stuff is easy to put on not cheep but good,
That's what I used and non of this heating tar etc or nailing
link
Jon Ison
| posted on 23/3/08 at 08:39 PM |
tiger seal ?
omega 24 v6
| posted on 23/3/08 at 08:40 PM |
Why not fibre glass it?? good practise for the kit repairs/alterations.
eccsmk
| posted on 23/3/08 at 08:54 PM |
never thought of that i used to fibreglass bus fronts when i left school and the bloke i worked for will supply the materials at the right price
thank you i think i might just do that
Volvorsport
| posted on 23/3/08 at 09:05 PM |
CFS for trims/GRP, make sure you use plywood (wisa/spruce)and not sterling board , and coat the top coat on before it gets rained on !
itll be a good lifetime before it needs work .
www.dbsmotorsport.co.uk
getting dirty under a bus
