scutter
posted on 3/4/08 at 06:01 AM |
O/T 307 tierods
I'm having a problem with the steering on the 307 SW.
It appears the L/H Tie rod has lots of play in it.
Is it possible to replace the tie rod and end on it's own? or am I looking at a rack replacement?
ATB Dan.
Paul TigerB6
posted on 3/4/08 at 09:08 AM |
is this the part??
track rod end
If so i'd definately give the local autofactor a ring for a price. Mine generally beats ebay prices by the time postage is added and often beats
the BIN price
[Edited on 3/4/08 by Paul TigerB6]
scutter
posted on 3/4/08 at 09:27 AM |
Paul, Cheers that's the rod end i'll replace as well, I'm after the tie rod from the rack to the rod end. The play appears to be
at the rack end of the tie rod.
ATB Dan.
Paul TigerB6
posted on 3/4/08 at 11:20 AM |
ATB Dan.
Think i'm with you now - so its the ball joint on the inner end of that tie rod then - the bit under the rubber boot in the pic.
inner
ball joint
I would think thats a part of the steering rack assembly myself. Dont think its a serviceable part with any adjustment myself but i only have
experience with Citroen steering racks.
cossiebri
posted on 3/4/08 at 02:22 PM |
Try gsf carparts-normally a lot cheaper than ebay, i was after a vdo oil pressure sender--£10 off ebay for a s/h one --£2.50 new from gsf !!
If it doesn't fit MODIFY it!!
Cheers BriF
